Author Topic: Meteohub/Meteoplug question  (Read 718 times)
Offline swyman18
« on: December 10, 2014, 09:14:43 PM »
Hi all,
I've been reading up on my various options for using MeteoHub/MeteoPlug and just wanted to confirm something.
If I understand correctly, MeteoHub does NOT support sending live/realtime (10 second) data to MeteoPlug, is that correct?  If I want to be able to send the 10 second data then I need to use MeteoBridge or the MeteoPlug client directly, does that sound right?
Thanks!
Offline docbee
  • Moderator
    • smartbedded
Re: Meteohub/Meteoplug question
« Reply #1 on: December 11, 2014, 02:54:47 PM »
Meteobridge and Meteohub and pure Meteoplug-Clients (not that often used) can all send reduced live data every 10 seconds and full raw data every 10 minutes.
Reduced live data is just the current values of the main sensors. This is used by Meteoplug live dashboard functions only.
Full raw data is all single data items the weather station has sent. This is bundled into 10 minute chunks to keep server load in reasonable bounds. Therefore, no data is lost. Any single set of data is processed, but graphs etc can be up to 10 minutes late.
Offline swyman18
« Reply #2 on: December 11, 2014, 05:13:31 PM »
Ok, thank you for the clarification. Will do some more research.
Thanks!
