Author Topic: clientraw.txt  (Read 2483 times)
Offline txweather.org
    • Texas Weather
clientraw.txt
« on: May 31, 2014, 12:43:08 PM »
Can meteobridge generate a clientraw.txt file similar to WD?
Regards.
Davis Vantage Vue|Meteohub 5.0l (Build 7293) Running on Debian 7.9 x86 (oVirt)|WU KTXSPRIN75/PWS JRARGWX75/CWOP EW2972/WBB TXWDVUE75/Blitzortung ID: 1142|AWEKAS: 12095
Offline wvdkuil
  • Wim van der kuil
Re: clientraw.txt
« Reply #1 on: May 31, 2014, 02:31:45 PM »
Regards.
No. Meteohub does generate that file. Meteobridge not, as it uses far smaller hardware.
Wim
Support for Leuven-Template & Scripts  at this forum
Support for the HWS-template for WD a.o.  http://wd34.weather-template.com/
Script sponsors https://support.leuven-template.eu/userlistScripts.php
Template sponsors https://support.leuven-template.eu/userlist.php
    • Texas Weather
Re: clientraw.txt
« Reply #2 on: May 31, 2014, 02:45:43 PM »
Thanks for the reply.
Does meteohub generate different types of files at the same time?
IE: MBtags.php, MBrealtime, clientraw.txt
Thanks for the help!
Offline wvdkuil
  • Wim van der kuil
Re: clientraw.txt
« Reply #3 on: May 31, 2014, 02:53:06 PM »
Yes. You can specify for each file to be uploaded the time. Both the Saratoga- and the Leuven-template need multiple file uploads of the types you mentioned. Fully supported by Meteohub. Meteobridge is also capable of uploading those files, excluding the clientraw files. There is no template file for Meteobridge for those rather complex files.
Wim
    • Texas Weather
Re: clientraw.txt
« Reply #4 on: May 31, 2014, 03:01:01 PM »
Awesome.
Thanks. I will have to figure out where I am going to install it. I might create a freebsd jail.
Regards.
Offline wvdkuil
  • Wim van der kuil
Re: clientraw.txt
« Reply #5 on: May 31, 2014, 03:05:40 PM »
Awesome.
Regards.
Well you should consider a RaspberryPI. Fully supported, see the Meteohub forum.
Works like a charm. And at least all parts of the hardware are inexpensive and easy replacable. Use the Raspberry/Meteohub myself now also.
Wim
    • Texas Weather
Re: clientraw.txt
« Reply #6 on: May 31, 2014, 03:07:07 PM »
Awesome.
Regards.
Wim
AHAHAHA!!!
Sweet! I just bough one! :D
Thanks!
Offline pimohdaimaoh
  • "Be aware to our nature"
    • PIMOHWEATHER
Re: clientraw.txt
« Reply #7 on: March 04, 2019, 08:58:18 AM »
Wim
Hello Wim,
Just asking is this meteohub can send clientraw.txt if seting it like 16 seconds or 10 seconds? I already tested weewx with interceptor but its update interval takes long, 60 second max interval is too long to considering changes to the weather units every 10 - 15 seconds. Hope you can confirm this so that I can decide to bought one
My test Site:
http://pimohweather.webutu.com
My CWOP ID: EW0758
    • Texas Weather
Re: clientraw.txt
« Reply #8 on: March 13, 2019, 09:35:27 PM »
Hello Wim,
Yes you can. The intervals are base on a cron system
