Author Topic: $doZoneTitles = true doesn't change output  (Read 756 times)
Offline Tailspin45
    • Carlsbad Science and Technology Observatory
« on: November 11, 2013, 10:37:05 AM »
In atom-advisory.php I've set $doZoneTitles = true, but the zone code is still displayed. I've googled and noodled without success.
BUT, I have a bigger issue that might be related, to wit: WeatherCat seems to be doing it's thing...at least as far as WeatherUnderground, CWOP and custom web services are concerned (according to the WCT status). But my site still reports that it's NOT CURRENT since Nov 4th. Nothing out of the ordinary occurred on 11/4, as far as I know, but something obviously changed.
My guess is I have an ajax issue, but I haven't a clue where it might be ...or how to fix it. Or, more to the point, how I broke it to begin with so i don't do it again.
Thanks in advance for your help.
Offline sacreyweather
  • Echo Valley Weather
Re: $doZoneTitles = true doesn't change output
« Reply #1 on: November 11, 2013, 11:34:03 AM »
Check and make sure your WCT_realtime.txt file is uploading onto your webhost, and check the date on it there. If this isn't uploading, your site isn't going to update.
Saline Weather on Twitter
Blitzortung Station 1387
Offline Tailspin45
« Reply #2 on: November 11, 2013, 11:44:32 AM »
Yup, it's dated 11/4. Thanks for the suggestion...now I just have to figure out why it's not updating.
I did check the files, and they seems to be original distribution, and haven't been parsed by mistake, and atom-advisory-CAZ043.txt has been created.
Thanks!
« Last Edit: November 11, 2013, 06:50:50 PM by Tailspin45 »
Offline dnavarrojr
    • WIBW News Now
« Reply #3 on: November 11, 2013, 05:16:12 PM »
I think PHP is case sensitive, so you might try "TRUE" instead of "true".
Dave Navarro, Jr. - Director of Digital Media - Alpha Media USA
WIBW News Now - https://wibwnewsnow.com
Offline Tailspin45
« Reply #4 on: November 12, 2013, 09:48:52 AM »
Update problem solved (updates going to the wrong place), but still getting zone abbreviation.
The script's instructions say to use 'true' or 'false' and "TRUE' or 'FALSE" does't fix it...but thanks for the idea.
« Last Edit: November 12, 2013, 09:56:04 AM by Tailspin45 »
