Author Topic: My home-made ferrite antennas  (Read 72687 times)
Offline dfroula
« on: August 15, 2013, 07:08:48 PM »
Here are some photos of my home-made ferrite antennas.
I found a source for some 7.5mm x 50mm ferrite rods with an initial permeability of 2000u - ideal material for a ferrite antenna, but too short to be of practical use. However, the price was very cheap! I ordered 32 of them to experiment with. I decided to try to make some 7.5mm x 250mm cores by gluing 5 of the smaller rods end-to-end. Gluing ferrite in this manner is an accepted practice and has a very small effect on the inductance of the final antenna.
Richo suggested that close-winding a single layer of AWG26 enameled wire on a 10mm x 200mm core, leaving 5mm unwound at the ends, would produce a ferrite antenna with outstanding performance. I figured that a 7.5mm x 250mm rod would be equivalent.
Here is a photo of the 50mm rods and the "Super-thick" commercial grade cyanoacrylate glue I used to assemble the longer rods. The salt shaker is not a part of the procedure!
One drop in the center of the rod is enough.
I used a piece of aluminum channel clamped into a table vice and lined with waxed paper to align the rods as they were glued together. The waxed paper prevents sticking to the aluminum. 30 seconds of pressure was applied to allow the glue time to set.
The third rod ready to be glued...
The final 250mm assembly of 5 rods. I allowed 30 minutes before removing the assembly from the channel. I allowed another 2.5 hours for the glue to fully cure before winding the cores.
This photo shows the first finished antenna. The cores were wound with 26AWG enamled copper wire. I used electrical tape to secure the ends and sections of the coil as I wound to prevent unraveling and to keep the windings tight. When I reached the far end, I loosely wound the free end back to the other end. This is the end of the coil that will be connected to ground, following the example of the commercial antenna provider.
A close-up of the finished first antenna and extra cores...
The second antenna completed and the two additional cores for a second antenna pair.
A close-up of the two completed antennas.
I slipped the antennas into foil-covered and grounded 3/4" PVC conduit sections with a longitudinal gap in the foil to prevent shorting the magnetic field. These things have incredible gain! I am still testing, but they appear to be giving my high-gain flat-panel loop some serious competition!
Re: My home-made ferrite antennas
« Reply #1 on: August 15, 2013, 07:32:08 PM »
Thanks for sharing the info. It doesn't look all that difficult to put together.
Where did you get the ferrites?
At this point, the start of winding is obvious, but did you identify it for phasing after is is in the PVC conduit? Did you shrink-wrap them like the ferrites that came from Germany?
When you get them running on your detector, it would be great to know how they compare with the flat panel.
Offline dfroula
« Reply #2 on: August 15, 2013, 07:40:52 PM »
Up and running now! http://projectmf.homelinux.com:8081 to see them in action (use Chrome to avoid scrambled display). Check the stats on lightningmaps.org, station 681.
They look to perform as well or better than my 52-turn flat panels, based on the last 60 minutes of detections.
I have not shrink-wrapped them yet. I may just use electrical tape.
I made a nice housing similar to yours, Greg, with the conduit "L" box and 3/4 inch PVC conduit, covered in aluminum foil with the slit.
Don
« Last Edit: August 15, 2013, 07:47:09 PM by dfroula »
Offline dfroula
« Reply #3 on: August 15, 2013, 07:55:10 PM »
I bought the ferrites here. Be sure to order the 2000u, 7.5mm x 50mm rods.
http://www.surplussales.com/Inductors/FerRods/FerRods.html
.75/ea for the 32 I bought! Dirt cheap. 2000u material is next to impossible to find.
I had them 3 days after ordering.
Don
Offline DanS
  • Chiang Mai weather
    • ThaiWx
« Reply #4 on: August 15, 2013, 08:08:10 PM »
Do you know the number of turns you ended up with?  I've been doing similar things here, playing with various tank circuits and ferrite antennas to get different gain results. TIA
Dan
Offline dfroula
« Reply #5 on: August 15, 2013, 08:33:46 PM »
Well, I used 26AWG enameled wire with a total winding length of 240mm. .42675mm thick, including insulation.
That would be 563 turns, 7.5mm diameter.
563 * 7.5 * Pi = 13528.65mm of wire or 522 inches of wire (43.5 feet).
Don
Offline DanS
    • ThaiWx
« Reply #6 on: August 15, 2013, 08:35:41 PM »
thks!
Offline dfroula
« Reply #7 on: August 16, 2013, 01:15:01 PM »
I tried a 1" drop test on the glued cores. Every joint fractured. The cyanoacrylate is NOT a good choice for gluing these rods. The assembly would be far too fragile and subject to undetected breaks.
I'll repeat the procedure this weekend using 15 minute 2-part epoxy.
Regards,
Don
Offline Beaudog
« Reply #8 on: August 16, 2013, 01:55:16 PM »
The cores look to be hollow. I would run a wooden dowel thru them prior to gluing (they might not even need gluing)them together this should make them considerably stronger and less prone to break.   I don't think it would have any if much effect on their Q.
Offline dfroula
« Reply #9 on: August 16, 2013, 02:39:25 PM »
No, the cores are solid.
Offline wxman44
« Reply #10 on: August 16, 2013, 05:45:11 PM »
If you were to shrink wrap the cores for strength prior to winding them, would that significantly impact performance?
Offline dfroula
« Reply #11 on: August 17, 2013, 09:21:56 AM »
That is an excellent idea. I re-glued the cores with epoxy last night after cleaning up the ends with alcohol. The joints seem strong, but I have the feeling that ANY glued joint is going to be inherently weak. Ferrite is a powder mixed into a binder. The brittle composite nature of ferrite does not have enough strength to support the glued joint.
There is sufficient strength to support winding the coils, but shear strength is low. Pre-wrapping the cores with shrink wrap would stabilize the glued joints laterally. In addition, spacing the windings away from the core should minimize the distributed capacitance and self-resonance.
Darn, the long pieces of shrink wrap I have are just a hair to small to get the 7.5mm rods through. Off to Lowes!
Best,
Don
Offline Cutty Sark Sailor
« Reply #12 on: August 17, 2013, 09:57:33 AM »
There are specially adapted epoxies for gluing ferrites. Google it.
« Reply #13 on: August 17, 2013, 10:34:45 AM »
I was wondering whether J-B Weld would work for this...
 :-k
Offline DaleReid
    • Weather at Eau Claire, WI
« Reply #14 on: August 17, 2013, 11:39:54 AM »
Got my kit of parts yesterday.  My youngest son was ecstatic since it came in a German language box with a cool clock on it.
He was crushed when I opened it.  Now I'll have to come up with some sort of consolation prize for him.
I'm very happy.
Nonetheless, IF one could find shrink tubing just the right size to get the cores in, why not put the assembly together without any glue at the joints at all, slightly compress the whole stack and then shrink the tube assembly?  No glue, tightly held, and apparently the function of a rod built up from many pieces, as long as the ends are in close approximation, don't need any sort of fixation to conduct the magnetic lines through them, and glue is superfluous to function.
JB Weld might be stronger, but then again the problem is that cores are inherently fragile already, and to expect the last few millimeters of a compressed substance to hold tight is really asking a lot.  I'm still interested in the idea of using a dremel or such to make a little dimple or 5mm hole into the rod so that a load capable glue like epoxy can get more area of purchase to adhere to and distribute the load from the rod next to it through more of an area than just those smooth surfaces.
Darn, I should have ordered MORE of those rods when the order went in.
ECWx.info
ECWx.info/t/index.php
Offline dfroula
« Reply #15 on: August 17, 2013, 12:44:52 PM »
Yep, I agree completely! The shrink wrap alone would likely be fine.
I just wrapped each epoxied joint tightly with electrical tape, rewound the cores, wrapped the assembly in thin foam packing and stuffed it in the shielded PVC for a tight friction fit. I'm finishing up the wiring and enclosure assembly now.
Don
I'm very happy.
Offline dfroula
« Reply #16 on: August 18, 2013, 09:59:09 AM »
There has been no degradation in performance with the re-glued rods. I do think that shrink-wrapping the glued rods before winding or the entire antenna assembly after winding. will provide excellent mechanical stability. Even if the glued joint were to fracture within the shrink tubing, I do not think performance would be affected at all, as the ends would still be held tightly together, as long as the shrink tubing extended past the ends of the assembly to provide pressure longitudinally.
I found 25 feet of 3/8 inch blue shrink wrap on Ebay for about $8.00 with free shipping. This is a great price. Lowes wanted $35.00 for 48 inches of the stuff!  Lots of colors are available at this price.  I'll use this stuff to protect and stabilize the assemblies when it arrives. I plan on making 3 sets of antennas from the 32 rods I ordered.
Egon warned me about unwanted self-resonance in the 10KHz to 100KHz area if I close-wound the wire directly on the ferrite. However, I looked at Richo's PDF file with frequency response plots of various ferrite antennas, including one very similar to mine (20CM, close wound to within 5mm of each end, directly on the ferrite). The response was perfectly flat across the 10KHz to 100KHz band. Self-resonance disturbances did not appear until much higher frequencies.
Best,
Don
Offline DaleReid
« Reply #17 on: August 18, 2013, 02:22:50 PM »
Don,
As always, thanks go to you and others with the first rigs up and also the time to do a bit of futzing about.
I'm off to sniff for shrink tubing.  Glad you told us the size the look for that will work with these rods from Nebraska.
Dale
ECWx.info
Offline dfroula
« Reply #18 on: August 21, 2013, 04:45:04 PM »
I received the shrink tubing for the ferrite antennas today. Following advice from the forums, I decided to encase the completed ferrite assemblies, re-glued with epoxy, in shrink wrap. I used 3/8 inch tubing which was just wide enough to slip the entire assembly inside easily. I then shrunk each end and the center portion, to insure that the ferrite segments were squeezed together by the wrap longitudinally. This ended up working really well. The final assembly is quite secure and break-resistant.
This is one of the epoxied re-glued cores, almost finished winding.
Just a few mm to go. The epoxied and taped joint can be seen beneath the winding.
The ferrite assembly being slide through the heat shrink
...and shrunk with the heat gun, starting with each end first
The wire lead end after shrinking.
The opposite end after shrinking
Before and after shrink wrapping
The second antenna being prepared
Two antennas completed
Four antennas completed. I made a total of six.
3/4 inch PVC conduit for housing the ferrites showing the aluminum tape shielding and slits
Components of the ferrite antenna housing. The antenna assemblies are wrapped in thin foam and friction-fit in the tubes. The tubes are tapped into the "L" box, where the connections to the shielded cabling to the amp are made. The tubes are friction fit into the "L" with a thin coat of silicone grease to ease assembly/disassembly. The same was done with the end caps.
The back and cover of the conduit "L" junction box.
Offline DanS
    • ThaiWx
« Reply #19 on: August 21, 2013, 06:06:11 PM »
Very professional looking job. 2 questions with the metal shielding, do you ground the shields to the circuit ground and is it important or does it matter the direction that the slot in the shield points when mounted? Thanks.
Dan
Offline dfroula
« Reply #20 on: August 21, 2013, 09:44:30 PM »
Shrink-wrapped antenna ready to wrap in live-rubber foam sheet.
Wrapped and taped in live rubber.
Padded antenna inserted into 3/4 inch conduit.
Wiring inside of "L" junction box.
Finished antenna system with DB9 connectors for easy antenna switching between loops and ferrites.
Side view
Offline dfroula
« Reply #21 on: August 21, 2013, 09:48:27 PM »
Dan,
The shields are tied to one side of the ferrite winding (the return wire from the winding end). Both wires are connected to the grounded side of the amp input, which is in turn grounded through the shielded Ethernet cable to the controller board and its ground.
The orientation of the slot makes no difference at all.
Best,
Don
Dan
Offline DaleReid
« Reply #22 on: August 21, 2013, 09:51:55 PM »
A  L O T of work to get these photos for the rest of us to look at and see what things other minds have thought of with fabrication that would have taken more time to figure out on our own, or serve as a jumping off point to modify as we have to with available materials.
What was the search you used for the heat shrink?  I find several, but wonder if you remember the vendor you chose?
Finally, what's live rubber?
ECWx.info
Offline dfroula
« Reply #23 on: August 21, 2013, 10:09:01 PM »
Here's the vendor I used. He had lots of other colors as well:
http://www.ebay.com/itm/111116696223?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
"Live rubber" is thin rubber foam sheeting that hobby shops sell to wrap model airplane fuel tanks in to prevent the fuel from foaming with engine vibration. Dubro makes and sells it in two-sheet packages. The stuff is hard to describe, except it is very spongy and resilient. It makes a great shock absorbing material.
http://www.amazon.com/Du-Bro-513-Protective-Foam-Rubber/dp/B0006NATXY/ref=sr_1_1?ie=UTF8&qid=1377139165&sr=8-1&keywords=Du-bro+rubber
Don
« Last Edit: August 21, 2013, 10:40:57 PM by dfroula »
Offline DaleReid
« Reply #24 on: August 21, 2013, 10:33:26 PM »
Thanks, I did grab a roll of it, knowing it was big enough to fit your antennas after wrapping, and shrank down enough to be snug.
I think I know the rubber you're speaking of, and saying it is used by RC'ers, I'll know where to look or a couple buddies who may have some from their building days.
It feels sort of funny if I remember correctly.
Thanks again.
ECWx.info
