Author Topic: VantagePro2 solar alarm, won't reset.  (Read 543 times)
Offline Paul03
  • Topton, NC. USA weather http://Toptonwx.com
    • Noon Day Sun Ridge Weather
« on: June 18, 2018, 09:06:28 PM »
We were away for two weeks and came home to my Pro2 beeping.  The message said it was due to high solar Rad.  Also, Hi Humidity alarm.  The unit is 8 years old, running nonstop without a glitch until now.  First I have never set any alarms and 2, I don't even have a solar detector!  I tried everything to stop the beeping and finally held the Done button for 5 seconds, and it quit.  Two hours later, it did it again.  Last resort I took it apart and de-soldered the piezoelectric buzzer.  It still says 'alarm', just doesn't beep!  Does anyone have a clue as to how to correct or how this could happen?
Need to add I'm downloading data to WDisplay and posting online to Wunderground et al. After my 'surgery', all is well except for the bogus alarm.
Re: VantagePro2 solar alarm, won't reset.
« Reply #1 on: June 18, 2018, 09:14:59 PM »
All the power sources disconnected - batteries, mains etc.?
Offline Paul03
« Reply #2 on: June 18, 2018, 09:28:28 PM »
Yes, pull all power for 10 minutes.  Also it was taken apart for 20 minutes waiting for the soldering pencil to heat. But same message is displayed twenty minutes after reboot.  But no noise. :)  Hey, thanks but I have to sign off until tomorrow.
Offline Paul03
« Reply #3 on: June 19, 2018, 06:53:52 AM »
It's been running fine for 16 hours except the alarm notices at the bottom and NO noise.  So just won't worry about it until the unit dies. Thanks!
« Reply #4 on: June 19, 2018, 09:14:06 AM »
You could try reloading/updating the firmware.
Offline Paul03
« Reply #5 on: June 19, 2018, 09:16:29 AM »
If it starts acting up I'll try that.  Since it's running smoothly without noise I'll just use as it is.  Thanks.
Offline WiFiLogger
« Reply #6 on: June 19, 2018, 05:24:26 PM »
Maybe you have alarm set. WeatherLink has config window to manage alarms. Other software not necessary.
Please check this simple procedure to clear all alarms in your console.
« Reply #7 on: June 19, 2018, 06:22:36 PM »
Occam's Razor.  :)
Offline Paul03
« Reply #8 on: June 19, 2018, 08:13:42 PM »
OK, 1st I tried to clear all alarms.  2nd, I've never set an alarm and haven't touched the buttons for 8 years. 3rd, it's quite so I no longer care.   Bushman, Yep!  Best for me was to cut out the voice! Out of SOUND, out of mind! :D
