Author Topic: NOAA Report Problem  (Read 2551 times)
Offline griffo42
    • Carina Weather
NOAA Report Problem
« on: January 09, 2018, 07:09:24 AM »
Hi all
I am using the Saratoga templates and Cumulus.
The NOAA report prepared by Cumulus correctly shows the "degree" symbol - see the attachment NOAA Report - Cumulus.
To get the Cumulus report into my Saratoga based website I run the program NOAAReportssaratoga.php.  The report which then appears in my website does not show the "degree" symbol at all - see the attachment NOAAReport - Saratoga.
Am I using the correct software to get from Cumulus to Saratoga for this?  If not, please suggest the correct one to use.
Otherwise can someone please suggest a fix so that the "degree" symbol is shown correctly in the Saratoga report and thus on my website.
griffo42 [ You are not allowed to view attachments ]  [ You are not allowed to view attachments ]
https://www.kstwx.net/index.php
Davis Vantage Pro2 Model #6152AU
Cumulus latest version
Saratoga Weather World template Cumulus plugin
Carina Weather, Brisbane.
Offline tmabell
    • Mishawaka Weather
Re: NOAA Report Problem
« Reply #1 on: January 09, 2018, 07:41:21 AM »
This has to do with the Character encoding on your page.  I had that happen and couldn't get it to cooperate so I added this code as a workaround:
<?php
ini_set
('default_charset'"");
Ken can tell you how to fix it the right way but that worked for me.
Online saratogaWX
« Reply #2 on: January 09, 2018, 11:55:14 AM »
The page in the iframe NOAA-reportssaratoga.php is coming in as UTF-8, and needs to be in ISO-8859-1 to display the degree symbol.
Insert in your php.ini in the document root of your website.
default_charset = "ISO-8859-1"
and that should fix the issue.
Offline griffo42
    • Carina Weather
« Reply #3 on: January 10, 2018, 07:29:31 PM »
Hi Ken
Thanks for your advice to fix my problem, however I must not have done it correctly as the problem is not fixed.
This is the report of this morning.  [ You are not allowed to view attachments ]
This is a scan cut of my website's root directory.  The php.ini file is in the folder "etc". [ You are not allowed to view attachments ]
Here in the attachment is the php.ini file.
I seem to have done something incorrectly.  Please suggest a fix in the light of all of this, if you are able to.
griffo42 (Keith)
Ed.note: removed 3rd attachment-it was a view-source of a wxforum.net page, not a php.ini file.
« Last Edit: January 11, 2018, 10:53:19 AM by saratogaWX »
Offline tmabell
    • Mishawaka Weather
« Reply #4 on: January 11, 2018, 07:23:49 AM »
Your experience mirrors mine.  I made all the changes that were obvious to me regarding the default_charset to no avail.  I too must have missed something.  I then resorted to adding the code I mentioned earlier in this thread to the top of the script and the issue was resolved.  As I said, this isn't the best way to fix it but it did work for me.  I have had so many issues since moving to PHP 7+ and I wonder if that may be the reason this suddenly started happening.
Online saratogaWX
« Reply #5 on: January 11, 2018, 10:54:38 AM »
The php.ini file would be in your public_html directory (which, according to the screen capture, is likely your website's document root).
Offline tmabell
    • Mishawaka Weather
« Reply #6 on: January 11, 2018, 11:25:50 AM »
In my case, this is the entry that defines charset:
; PHP's default character set is set to empty.
; http://php.net/default-charset
; default_charset = "UTF-8"
While UTF-8 is the problem I was under the impression that by leaving it blank or commenting it out would allow scripts, etc. to define the character set as needed for each one.  Am I off with my thinking?
Online saratogaWX
« Reply #7 on: January 11, 2018, 11:38:25 AM »
Sometimes, it's the Apache httpd.conf that sets a default character set (if the PHP doesn't).   The PHP order of processing is the master php.ini, then overrides by the php.ini in the document root (if any).   PHP 7+ defaults to UTF-8 if it's not explicitly specified.  PHP 5 used ISO-8859-1 default if not explicitly specified.
Offline tmabell
    • Mishawaka Weather
« Reply #8 on: January 11, 2018, 11:46:20 AM »
Now I understand.  That would explain why the degree symbol got strange after the PHP upgrade to 7.  Thanks very much Ken, I will make the needed changes.
EDIT:  That fixed the issue!
« Last Edit: January 11, 2018, 11:52:39 AM by tmabell »
Offline griffo42
    • Carina Weather
« Reply #9 on: January 11, 2018, 08:41:36 PM »
Despite copying the php.ini file from the 0:/etc folder to 0:/ root  and/or to my 0:/public_html folder none of these worked for me.
I tried tmabell's fix shown in his first post and that works for me.
It annoys me that I can't fix it according to Ken's suggestions but I don't know enough about programming in PHP.
Thanks to both for all your help.
griffo42 (Keith)
