Author Topic: Weather Link 6.0.3 Install from CD  (Read 1783 times)
Offline shirsch
« on: December 28, 2017, 07:22:36 PM »
I am trying to install Weather Link 6.0.3 from CD and keep getting an error message when install is almost completed.
The message is "There is a problem with this windows installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor."
I am trying to install on a Lenovo i7 laptop with windows 7 and 32 gb of ram. I tried to install a downloaded copy but same problem.
Any ideas?
Steve
Re: Weather Link 6.0.3 Install from CD
« Reply #1 on: December 29, 2017, 08:42:47 AM »
Not sure, since I didn't experience this problem that I recall. (it's been a few years)
Did you try installing as an "administrator"?
Offline shirsch
« Reply #2 on: December 29, 2017, 08:56:41 AM »
yes but same issue
Offline cirrus
  • Kevin Hough
  • Davis Vantage Pro2 Plus
    • Gorge-East Weather
« Reply #3 on: December 29, 2017, 06:31:41 PM »
The WeatherLink CD also installs DotNetFX35 and Visual C+... see if those installed completely..  you can open the CD and run those installs manually to see what happens or possibly do a repair?
Regards, --Kevin
Offline shirsch
« Reply #4 on: December 31, 2017, 08:12:14 AM »
Tried that still no go....email tech support a few days ago and no answer yet
Offline dupreezd
« Reply #5 on: December 31, 2017, 08:23:39 AM »
Have a look in Event Viewer, Windows logs. Start with Application, then Security and System. It might give you an idea why the install failed.
Davis VP2 6163 | WiFi Logger
CWOP - FW0717
Blitzortung 2100
