Author Topic: Vanatge Pro 2 Console Problem  (Read 2970 times)
Re: Vanatge Pro 2 Console Problem
« Reply #25 on: December 10, 2017, 06:00:27 PM »
Thanks Dale,
I know Gord and him being a HAM, could this be an issue because of his other equipment in the house?
What frequencies does he transmit on? Are they in (near or a multiple of) the ISS's 902-928MHz bandwidth?
Not saying it can't, but how would RF affect a baro sensor?
It (RF) would NOT affect the sensor itself, but rather its ELECTRONIC circuitry devices.
Ahhh yes, didn't think of that. Maybe he should make a little Farady cage to temporarily experiment with.
Offline Old Tele man
  • Singing in the rain...
« Reply #26 on: December 10, 2017, 06:46:02 PM »
A simple (grounded) "Tin-foil" hat...
« Last Edit: December 10, 2017, 07:50:25 PM by Old Tele man »
Offline VA3TWT
    • Blenheim Weather
« Reply #27 on: December 10, 2017, 07:17:42 PM »
I did have the console right next to my radio gear, and I have now moved if a few feet away.  I will do more testing.
Thanks all!
Gord
Offline dalecoy
    • Lee's Summit, MO
« Reply #28 on: December 10, 2017, 07:36:12 PM »
Thanks all!
Gord
I'm glad I asked.  Now is the time to remove all power (battery and AC) from the console, wait a minute, and restore power.  That might get the barometric reading back - although I doubt it.
After you get a replacement console, it would apparently be advisable to not have it right next to your radio gear.
Out of curiosity - exactly what piece(s) of equipment was it near?
de W5VBQ
Offline VA3TWT
    • Blenheim Weather
« Reply #29 on: December 10, 2017, 07:44:52 PM »
There was a 30 amp power supply above the console, an LDG autotuner and an IC-7100 transceiver below it.  There was  a Motorola speaker on one side, with nothing on the other side.
« Reply #30 on: December 11, 2017, 08:58:40 AM »
Is the IC-7100 running barefoot, or do you have an amplifier?
In addition to the frequency question, what kind of antenna do you have. What is the distance from the antenna to the console?
It might be worthwhile to add a clamp-on ferrite filter appropriate to the offending frequencies to the USB and maybe another one to the console power.
73 de KE8DAF
Offline VA3TWT
    • Blenheim Weather
« Reply #31 on: December 11, 2017, 09:05:57 AM »
IC-7100 is barefoot and connected to a Hustler multi-band vertical which is about 30 feet away. I will add the ferrites as suggested.  Thanks!
73 de KE8DAF
