Author Topic: Adding LED (or?) to shield fan help  (Read 11596 times)
Offline Bashy
  • brecklandweather.com/meteo
    • Breckland Weather
Re: Adding LED (or?) to shield fan help
« Reply #100 on: July 21, 2017, 01:13:12 AM »
Hi Mick,
None of my fans state the max mA or any mA for that matter, i know one needed about 1A going by the meter on my psu
Added  a options for night  mode  LDR is to switch the fan off  automatically
Is there an option for lower voltage (slow the fan) instead, some fan movement will be better than none i think
Just wondering if to have an option to add a 12v fuse on the 12v dc  power input?
why? in case of over voltage? wired wrong etc?
« Last Edit: July 21, 2017, 01:15:36 AM by Bashy »
Kind regards
Bashy
Offline Bashy
    • Breckland Weather
« Reply #101 on: July 21, 2017, 11:49:04 AM »
Hi Mick
To be honest with you, the idea of lower speeds for night time was just that, an idea, mostly to save a little
on cost and fan wear and tear. I think i will just keep my fan running constant day and night. I am between
0.5 - 1C+ on the met office station, sometimes i am level, but i am mostly above theirs, so i will be changing
the fan to higher cfm when i take it down again.
My fan is running on 12v mains, i optoed for the cheaper daytime fars with the idea to convert it to 24/7 using
the mains, thats the way to go if you do go for Davis, saves you a little :)
I think i will just use one on the Davis, i can hear the OS where it is just by walking up to it as its head height :)
Kind regards
Bashy
Offline Bashy
    • Breckland Weather
« Reply #102 on: July 23, 2017, 02:32:31 AM »
HI Mick, thanks for the video, just one point, when you stop the fan by hand, slowly turn the fan, once
it hits one of the 4 points see if it will turn off the LED again, could you try that please?
This is why i had to go for flashing LEDS on my mod, flashing because, when the fan is running, one LED
is flashing normally, thats just to show theres power, the other LED (for the fan), looks like constantly lit
because of the speed of the fan, so if the fan fails, it will do 1 of 2 things, either go out or start flashing
depending if its hit one of the 4 thingys (<<scientific term that is) inside the fan or not, it was the only
way i could figure it out :)
Kind regards
Bashy
Offline Bashy
    • Breckland Weather
« Reply #103 on: July 23, 2017, 09:24:15 AM »
Thats great, sound like progress,
Just a thought, could you add expertise to this thread please?
 Trying to see if we can copy the Davis leaf sensor :)
Kind regards
Bashy
Offline Bashy
    • Breckland Weather
« Reply #104 on: August 27, 2017, 05:39:34 AM »
Glad I have this led, the led went out today, power one was still flashing so there was sommat up with the fan,
Turned out there was a dry solder joint on the board, all good again :) it works......
Kind regards
Bashy
Offline dupreezd
« Reply #105 on: August 27, 2017, 08:44:09 AM »
 =D&gt;
Davis VP2 6163 | WiFi Logger
CWOP - FW0717
Blitzortung 2100
