Author Topic: Updating EIT 304 and SOHO realtime image  (Read 799 times)
Offline pimohdaimaoh
  • "Be aware to our nature"
    • PIMOHWEATHER
« on: March 28, 2017, 03:58:57 AM »
I update the realtime image for my wxspace section in which anyone and me also can distinguish the changes of sun's coronal easily and SOHO images because if viewing in still image or stack image, you can hardly monitor the lapse time when the coronal changes occured in time, including the LASCO, this helps me to Identify the exact changes of coronal wavelength when reading the result in volts per m2 wavelength in actual and you will see the changes per lapse and after time updates. Now I easily monitor most of the sun's active corona or sun spot blows in space than a STILL image views, sine the SPRING season in my country is actually SUMMER to us, I have to monitor the sun spots because extreme blow of corona waves may boost the extreme heat detecting from our weather sensor and not just the sorunding heat index.
http://pimohweather.webutu.com/wxspace.php
« Last Edit: March 28, 2017, 04:12:18 AM by pimohdaimaoh »
