Author Topic: Run Saratoga Template at regular times  (Read 1292 times)
Offline griffo42
    • Carina Weather
« on: March 23, 2017, 06:05:39 AM »
Hi all
I wish to run the Saratoga template each day at a regular interval..Could I please have recommendation as to the best way to achieve this.  There is a way to set up Firefox to run in this proposed way but I am wondering if there is a better way.
https://www.kstwx.net/index.php
Davis Vantage Pro2 Model #6152AU
Cumulus latest version
Saratoga Weather World template Cumulus plugin
Carina Weather, Brisbane.
Online wvdkuil
  • Wim van der kuil
Re: Run Saratoga Template at regular times
« Reply #1 on: March 23, 2017, 06:48:08 AM »
The easiest way is to use a cron-job to to the job for you.
A google search for "free cron jobs " results  multiple possibilities.
You select a cron job provider
enter the url to be executed: http://www.kstwx.net/index.php  or any other page of your site,
set the frequency, once a day, or every so many minutes
and the cron provider will execute that url at the set frequency.
Example https://www.easycron.com/user/register  allows 200 executions of your set URL per day. That is every ten minutes every day.
And there are multiple other also to choose from.
Maybe you provider also allows cron-jobs but often the setup is more difficult and the frequency allowed is less attractive. But that differs for every provider.
Wim
