Author Topic: saratoga template, not showing up on website ?! help please!!  (Read 9603 times)
Offline wthrmn654
    • Mikes Weather Station
Re: saratoga template, not showing up on website ?! help please!!
« Reply #75 on: August 27, 2016, 08:04:40 AM »
As you all can see it's working.however haven't figured it the forecast part yet.
Offline Jáchym
  • Meteotemplate Developer
    • Meteotemplate
« Reply #76 on: August 27, 2016, 09:52:47 AM »
OK, it should be ok now, but I only set your default one. I left the other ones in the select box.
Offline wthrmn654
« Reply #77 on: August 27, 2016, 10:03:04 AM »
Oh thanks. When I get time I'm going play around with it more lol I have everything in boxes so MY computers not accessible lol
Offline Jáchym
    • Meteotemplate
« Reply #78 on: August 27, 2016, 10:18:27 AM »
Well at least I set you default one for now, which is what most people see when they first enter your site. What you set for the other ones is really up to you.
Offline W3DRM
    • Emmett Weather
« Reply #79 on: August 27, 2016, 12:25:15 PM »
Now that you have your website working, I have one suggestion - make a backup copy of all of your files to a separate area on your disk or to a thumb-drive. That will give you a means of restoring to a known, working website should you accidentally make a mistake while making updates and refine your website. It will save you a lot of time and frustration should something go wrong. Do this on a regular basis and you'll always have a working version ready to go, if necessary.
BTW, congratulations, you've come a long way since your first post in this thread 14 days ago!  =D>  Keep going, take it step by step and before long you'll be an 'expert' in PHP...  ;)
--- RIPE Atlas Probe - 32849
Offline wthrmn654
« Reply #80 on: November 29, 2017, 05:45:01 PM »
Ok so yeah, my idiot dad changed the router and after saying he would wait for me of course.  I of all things accidentally reset the mrteobridge and now i forget whast was being uploaded to my site through ftp. I'm actually about to delete the whole fing site and break my phone in half as i broke the screen protector again while grubby to fix the dam metrobridge before.  I  top of having a bad month, or months and then there's the girls problem.. fml
Fml fml do fml
Offline Jáchym
    • Meteotemplate
« Reply #81 on: November 29, 2017, 05:58:21 PM »
OK, so what exactly is the problem now? :D
Offline wthrmn654
« Reply #82 on: November 29, 2017, 06:11:26 PM »
Lol well,  back too setting up the ftp on the mrteobridge and what exactly is getting sent through ftp.. was it 2 or 3 things.
Offline wthrmn654
« Reply #83 on: November 29, 2017, 06:17:06 PM »
Ok so i see there's 2 things that get updated metrobridge ftp and meteobridge data. If i knew what those 2 things are ill be fine.
Offline Jáchym
    • Meteotemplate
« Reply #84 on: November 30, 2017, 07:48:58 AM »
in Meteobridge you can set sending data to either built-in weather networks (including some templates like mine), or you can set sending data to FTP with a format you define. I assume you are using Saratoga, in which case if I remember correctly you send data via FTP using the predefined file template, but unfortunately I never used Ken´s template so I recommend asking him directly or someone else using this template
Offline wthrmn654
« Reply #85 on: November 30, 2017, 09:41:44 AM »
If i recall correctly i think i set up the whole ftp upload stuff, i just can't seem to find, at least yet,  what needs tip be updated regularly,  etc. The real time info stuff,  temp forecast etc.
I've had little to no time to re-read through all the posts.
Offline Jáchym
    • Meteotemplate
Offline wthrmn654
« Reply #87 on: November 30, 2017, 01:06:57 PM »
Yes you helped me there greatly, just fighting with my ftp. I need to set the template and then the path file i know already.
« Reply #88 on: November 30, 2017, 01:15:22 PM »
Don't forget to have Meteobridge use the gen-MBtags.php as the template source to create MBtags.php in the Meteobridge setup.
The screenshots shown in the link Jachym posted (thanks!) are for an earlier version of Meteobridge, but the instructions about WHAT to use are still valid.
You'd use http://wthrmn654.bravehost.com/gen-MBtags.php for the template and FTP MBtags.php to your site.
Then use http://wthrmn654.bravehost.com/wxstatus.php to show if the setup was successful (current data posted).
Offline wthrmn654
« Reply #89 on: November 30, 2017, 05:06:45 PM »
great and helpful information, and everything should be working, only problem is i can't get the dam ftp to work and idk why!
Offline wthrmn654
« Reply #90 on: November 30, 2017, 05:07:58 PM »
only thing thats changed update wise is the forecast... fml lol idk why im having ftp logon problems suddenly..
« Reply #91 on: November 30, 2017, 05:20:37 PM »
FTP issues can be caused by:
1) invalid userid or password for FTP
2) invalid hostname
3) using Active instead of Passive for connection type (some hosts are particular about that)
4) using the wrong path for the uploaded filename.  You have to specify public_http or httpdocs (depends on webhoster) usually
  for mine, I have to use 'httpdocs/MBtags.php' to get it to work.
What does the Meteobridge status say for the FTP upload on the 'Live Data' tab?
Offline wthrmn654
« Reply #92 on: November 30, 2017, 05:25:17 PM »
live on meteo shows nothing its blank... im just so pissed i pressed the reset button for to long and lost everything as it took a while to figure out first time... and i didn't even post what i had to do on here sadly to get it to work.. web making is so freaking stressful when it isn't saved and you lose everything!
Offline Jáchym
    • Meteotemplate
« Reply #93 on: November 30, 2017, 05:27:18 PM »
If the "Live" tab in MB is blank then there is a general issue in the communication between your station and MB. In such case this is what you must solve first. If nothing is on the Live tab, MB is not getting any data and wont send anything to your website even if the FTP was set correctly.
Offline wthrmn654
« Reply #94 on: November 30, 2017, 05:29:49 PM »
no the station is working fine and shows everything the ftp and sftp colums dont show any uploads...  i have got it saying theres no such file or directory when trying to do a test upload so its progress just can't remember how to test it exactly. what i thought would of worked didn't
Offline wthrmn654
« Reply #95 on: November 30, 2017, 05:48:31 PM »
hmm any idea how to  test something to my host? everything ive tried to do isn't working so im not sure how to fix this again.
Offline wthrmn654
« Reply #96 on: November 30, 2017, 06:15:25 PM »
alright so i left the path blank to do test, and i think success... System Message
FTP test upload successfully done, file 'test-upload' stored on FTP server
now i need to double check the files im sending so far nothing but maybe soon success. i believe that the default pathway was altered somehow so that should now be fixed..
Offline wthrmn654
« Reply #97 on: November 30, 2017, 06:31:57 PM »
well for now im stumped test is successful, but the uploading of template and pathway aren't working or doing anything im pretty sure i have it all plottted correctly but i keep getting a no upload display on the live section.
Offline wthrmn654
« Reply #98 on: November 30, 2017, 06:48:02 PM »
success everything is sending again but i dont see anything updating other then status page... is there something else i need to do ?
Offline wthrmn654
« Reply #99 on: November 30, 2017, 06:54:02 PM »
correction i fixed it. added http upload of ajax.
