Author Topic: Cumulus uploading blank realtime.txt file  (Read 5026 times)
Offline ch8ch
  • ***ch8ch***
« on: February 23, 2016, 09:05:57 PM »
Jachym was kind enough to donate his time to helping me setup a weather site. I was working well for an hour or so after his initial configs. We are both puzzled by the fact that my Cumulus is uploading a blank realtime.txt file and now the station is offline. Initially on setup we saw the same issue until I played with the internet settings and got it to work. Now it's doing this again and the site hasn't updated since 7:13 PM EST....  FTP settings are correct and it is being uploaded to the directory. 0 bytes....
Has anyone using CUmulus 1.9.4 seen this issue before?
Offline mkutche
    • GosportWx.com
Re: Cumulus uploading blank realtime.txt file
« Reply #1 on: July 14, 2016, 08:12:04 PM »
mine uploads for a few hours and then quits and goes to 0 kb i have to delete the realtime.txt from server and reupload one from cumulus directory on my desktop and then restart cumulus program.. very annoying.. Idk how to fix it hope someone can weigh in
Mike K.
Gosport, Indiana
« Reply #2 on: July 14, 2016, 09:54:11 PM »
I have not had any issue with uploading Cumulus realtime.txt to my webserver.
Is the realtime.txt file that is saved in the Cumulus root folder valid?
You could try by making a duplicate realtime file (realtimeT.txt) to be processed and uploaded by Cumulus through the extra files process at realtime interval.  That is what I do and upload that to a separate webserver folder for another specific template set.  So in fact I have 2 realtime.txt files but in separate webserver folders.
Offline mkutche
    • GosportWx.com
« Reply #3 on: July 15, 2016, 04:18:29 AM »
Before my server crash it was uploading fine and I haven't touched a thing on it.. Weird and the FTP logs don't give an error it just uploads a blank realtime.txt hmm. And its uploading the same way before I had to reup everything.
Mike K.
Gosport, Indiana
Offline ericfynne
« Reply #4 on: July 15, 2016, 04:36:39 AM »
I have seen cases where blank files are caused by firewall changes somewhere between the PC and the ftp server, and the solution is to to switch from active to passive ftp mode or vice versa. You could try that, it may help.
Offline mkutche
    • GosportWx.com
« Reply #5 on: July 15, 2016, 04:51:56 AM »
I don't see passive mode on cumulus
Mike K.
Gosport, Indiana
Offline mcrossley
    • Wilmslow Astro
« Reply #6 on: July 15, 2016, 04:53:05 AM »
Another cause is a zero length file on your web server created by some transient failure. This causes subsequent FTP process to fail, simply delete the empty file from your web server and Cumulus should start working again (usually it doesn't even need a Cumulus restart - but if it still doesn't work then restart Cumulus).
Offline mkutche
    • GosportWx.com
« Reply #7 on: July 15, 2016, 04:54:13 AM »
Yep done that a thousand times aday lol
Mike K.
Gosport, Indiana
Offline mcrossley
    • Wilmslow Astro
« Reply #8 on: July 15, 2016, 05:00:40 AM »
Ah! A bit more than my 2 or 3 times in ten years then!
From what I remember Cumulus attempts to keep the realtime FTP session open permanently. Do you have access to the server FTP error logs?
Offline mkutche
    • GosportWx.com
« Reply #9 on: July 15, 2016, 05:39:01 AM »
I think my dad does I will look at that.
Mike K.
Gosport, Indiana
Offline ericfynne
« Reply #10 on: July 15, 2016, 06:16:00 AM »
"Use Active FTP Mode"
Set = Active mode
Unset = Passive mode
as described in the help.
« Reply #11 on: July 15, 2016, 09:17:50 AM »
Did you confirm that the realtime.txt in your Cumulus folder is blank?
Can you try by having Cumulus process and upload a realtimeT.txt (http://wiki.sandaysoft.com/a/Realtime.txt) to realtime.txt.
Offline mkutche
    • GosportWx.com
« Reply #12 on: July 15, 2016, 10:16:18 AM »
Its not working again.. Its in passive mode and I have cumulus processing realtime.txt this is crazy.. Does it need to be chmodd 775 on websever??
Mike K.
Gosport, Indiana
Offline ericfynne
« Reply #13 on: July 15, 2016, 10:20:37 AM »
Its in passive mode
And you get the same problem in active mode?
Offline mkutche
    • GosportWx.com
« Reply #14 on: July 15, 2016, 10:26:12 AM »
Its in passive mode
Yep. I just have to delete realtime wait 5 minutes for it to reupload. Grr
Mike K.
Gosport, Indiana
Offline ericfynne
« Reply #15 on: July 15, 2016, 10:27:47 AM »
Ah, OK. Looks like a problem with the ftp server to me, but I'm no expert.
Offline ericfynne
« Reply #16 on: July 15, 2016, 10:29:26 AM »
Wait.. 5 minutes? You have your realtime update interval set to 5 minutes?
Offline mkutche
    • GosportWx.com
« Reply #17 on: July 15, 2016, 02:07:59 PM »
5 seconds I mean.
Mike K.
Gosport, Indiana
« Reply #18 on: July 15, 2016, 03:10:08 PM »
I am still unclear if the realtime.txt in your desktop Cumulus folder contains data or not.
If it is FTP issue then this will likely not do anything for you, but since you are on build 1097 you could update to the most recent build 1099 and that may eliminate Cumulus as the cause.  However, reading the release notes the changes from build 1097 to 1099 does not include anything re FTP.
Offline mkutche
    • GosportWx.com
« Reply #19 on: July 15, 2016, 04:53:09 PM »
I just never had this problem before..
Mike K.
Gosport, Indiana
Offline Maumelle Weather
    • Maumelle Weather
« Reply #20 on: July 15, 2016, 08:42:25 PM »
Mike,
I'm currently looking at your realtime.txt and it looks normal to me.
Edit: It was working, now I can't connect to his site.
« Last Edit: July 15, 2016, 08:54:23 PM by sacreyweather »
GR2AE, GR3, Cumulus
« Reply #21 on: July 15, 2016, 10:10:04 PM »
It is now updating every 5 sec.
