Weather Software > Weather Display
Custom file does not exist C:\wdisplay\webfiles\testtags.txt
(1/1)
KK7X:
Trying to get WD to display properly. Version 10.37S81 Registered. Testtags V 1.7. Went through setup several times and also used the wizard. Showing
testtags.txt and testtags.php in Special File Conversion. What could it be.
http://rathdrumweather.us/newajax/
chief-david:
are you saying that the testtags.txt is not being created by WD?
Create it yourself. put it in your files and see if WD fills it in during upload.
KK7X:
testtags.txt is located in C:\wdisplay\webfiles but is not being updated/uploaded
Create and upload testtags.txt as testtags.php is checked in Web Files Setup #1
I downloaded the WD template files from Saratoga and added the new test tags to Version 1.7
Thinking of just starting over from scratch.
KK7X:
The testtags.php is being created but not uploading. Running version 10.375 so it should work.
I am guessing the solution is to do Manual setup of testtags.php upload. It should be working
without this step. Thoughts anyone?
