Author Topic: All went down the drain today  (Read 2454 times)
« on: August 12, 2011, 05:39:27 PM »
Started at 10:30 Friday morning
my site is asking for a log in--- pic below.   BTW no login I have tried anything that would log me into school computers.
1. Is this a server/host issue?
The time is sort of correct but the graphs are not correct.  WL 5.9.3 only says that it cannot make the insidetemp.gif but no other images are being uploaded
WL is reading the station fine.
Wednesday-I set up a new computer with 5.9.3, VP live, VVP and Startwatch.
It was all working until this morning.  I went to school and unhooked everything, restarted with/without  VP, VVP, Start.
Nothing worked.
Still think it is a server issue.  Of course it is Friday-and I am going on vacation next week.
Luckilly, I can put it out of my mind and not really worry about until I get back. (newbies-it took me three years to get to that point)
thoughts?
« Last Edit: August 12, 2011, 05:53:18 PM by chief-david »
Offline Cynjut
    • Bellevue, NE local weather
Re: All went down the drain today
« Reply #1 on: August 12, 2011, 06:18:54 PM »
There are lots of variables here:
1)  Is it possible that someone set up a new server with your old IP address?
2)  Is it possible that your local DNS administrator has modified your IP address in the Domain Name Server?
3)  If you are running Apache, do you have access to the home directory for the website weather.rms.drale.org/?
4)  If you are running IIS, check the authentication options on the server for that sub-website.
5)  Check to make sure that someone hasn't added authentication to rms.rdale.org.
6)  Check your log files, assuming you can get to the server.  Make sure that your username is being correctly dis-recognized.
7)  Make sure that no one has change the .htaccess file to require authentication.  If they have, make sure the username file is accessible.
Without knowing your server platform, it's going to be hard to troubleshoot from outside.
Offline dkinsc
    • ClemsonKFAP Weather
« Reply #2 on: August 12, 2011, 06:19:35 PM »
I get the same message.  You need to speak to the responsible systems admin at rdale.org
Del
Del
KSCCLEMS2 and DW6419
« Reply #3 on: August 12, 2011, 06:49:24 PM »
I think all are very possible.  Those sound like administrator issues.  I have emails in.  They are making updates, but it is Friday.
for #5-can that be done from the outside? I was even looking for code in my htx. Could not see anything.
If the system admin put an authentication on the site-would that stop the graphics from being uploaded?
My weather computer could see the server area, but the WL images didn't update.  Sounds more server-ish to me.
« Last Edit: August 12, 2011, 06:59:32 PM by chief-david »
Offline BurnsvilleWeather
  • Burnsville, MN USA
  • Retired from Weather!
« Reply #4 on: August 12, 2011, 08:31:08 PM »
They locked down the IIS site and no longer allow anonymous access.  You need to get them to turn on that access again for your site.
www.BurnsvilleWeatherLIVE.com (Formally Webster Weather LIVE)
Home of the Alternative Dashboard and Mobile Dashboard Scripts. Weather Display Scripts and Graphics
Davis VP2 with, UV, Solar, Leaf, Web Cam.
Offline ed2kayak
  • Ed
    • Cumberland Valley Weather
« Reply #5 on: August 12, 2011, 08:44:30 PM »
Just now I hit cancel and got on site?
Ed
    • Watts Bar Weather
« Reply #6 on: August 12, 2011, 09:04:32 PM »
I did that, too, and although the time at the top is wrong, the times on the radar screens seem right.  the gauges all say 10:31 am.
« Reply #7 on: August 12, 2011, 09:10:21 PM »
When it refreshes, it will do it again
graphs did not update all day.  Can't figure that one out yet.
The computer shut off at 4:45.  ](*,)  That needs to be fixed too.
Won't be back on until Monday.  ](*,)
« Reply #8 on: August 15, 2011, 11:23:17 AM »
authentication gone.  Waiting for someone to start computer at school.
Then I can tackle other issues if there are any.  It all seemed to start at the same time.
« Reply #9 on: August 16, 2011, 03:55:15 PM »
Looks like it was all a system issue.  Not my fault or VP live, VWS.  \:D/
The authentication was the big problem.  It is updating.
May or may not go down again because of system work and auto time shut off.
Thanks all.
This "hobby" drives me crazy.
« Last Edit: August 16, 2011, 05:23:15 PM by chief-david »
« Reply #10 on: August 18, 2011, 10:08:13 PM »
New computer does an auto shut off at 4:45
Going back to old computer tomorrow-
