Author Topic: Solar Radiation Shield for Fine Offset - Works Pretty Well  (Read 890 times)
Offline Farmtalk
  • Fitzweather
    • WV Waterfalls
I've had an Ambient WS-1090 fine offset station running for about the last four months now. Recently, I was noticing that I was receiving my high temperature reports around 5:30 p.m., which seemed a little late to me considering my latitude (about 38 degrees N). I started checking the station graphs by day and was noticing about a five - seven degree spike in temperature during that time frame because the sun was hitting it.
The WS-1090 to me is a nice station for the price - no Davis or any flagship - but a good starter. But one thing it does lack is much of a solar radiation shield. I mean it's as thin as an eggshell practically, and I knew then and there that I was going to have to do something.
I work at a news station as the morning producer, so the money isn't great to where I could build or buy a Stevenson screen, but I did see that Ambient sells their own add-on solar radiation shield. So I gave it a shot.
This shield is huge! It is about the size of a basketball, and the sensor itself is about the size of a thermos, so you can imagine the surprise when I saw how big it was. After assembling it and attaching to my pole, I have given it a few days to see if it improved the data accuracy any, and I can say for sure that it does.
Now, I see usually no more than a degree increase as a result of sun, which for this station is doing pretty well. Eventually, I'll move up the ranks to a Davis or perhaps something else, but times are different for now.  8-)
So if there is anybody using a fine offset out there with a similar issue, I would say the solar shield is definitely worth the $40 tag.  8-)
Joe Fitzwater
Chief Meteorologist for WVNS-TV 59 in Beckley, WV
Work Page on Facebook -> www.facebook.com/meteojoe
Work Page on Twitter -> https://twitter.com/meteojoe
Waterfalls -> www.wvfalls.com
Offline wxtech
    • Lexington, Ga. Weather
Re: Solar Radiation Shield for Fine Offset - Works Pretty Well
« Reply #1 on: May 17, 2018, 09:03:46 PM »
Very interesting station.  I have a problem with trees shading the sensor early morning with low sun.  Couldn't fix it.  I have the Ambient shield also, no longer used.  I have some smaller shields packed away somewhere.
Impressed that you capture the daily CoCoRaHS county rainfall map for your site.  How do you do that?  Is it automated/software?  I have a Davis VP2+, old, fungi covered, needs refurbishing.  Ambient is my favorite equipment source.
Since you're working at a news job, see if NWS will outfit you with a CoOp station.  Free eqpt installation.  You would be good publicity for NWS.
Offline Farmtalk
  • Fitzweather
    • WV Waterfalls
« Reply #2 on: May 18, 2018, 03:09:49 AM »
If you have any shields you are not using that might fit right around the sensor itself that would fit inside the big shield, let me know.  :-)
Are you talking about this page? http://fitzweather.org/wxcocorahs.php
I can send the file if you wish - I found it here on the forum. The only thing that sometimes does not work for me with it is that I get up REALLY early for work (between 1:30 a.m. and 2:30 a.m.), and I measure my CoCoRaHS measurements at 3 a.m. The company seems to like the uniform 7 a.m. time and my measurements sometimes do not show up in the script as a result.
It isn't the script because other county reports show up for the day, just not mine. But I do not really have a choice on the matter right now.
That's a great idea.  8-)
Joe Fitzwater
Offline wxtech
« Reply #3 on: May 18, 2018, 07:56:19 AM »
The attached photo compares the 2 shields. [ You are not allowed to view attachments ]
It is too big to fit inside the Ambient shield.
Offline Farmtalk
  • Fitzweather
    • WV Waterfalls
« Reply #4 on: May 18, 2018, 09:48:35 AM »
That shield is huge!  8-)
I think the larger shield would certainly take care of any radiation issues!
I use just a simple 8 feet metal pipe to brace everything off of, but eventually, I would like to use a more sturdy tower structure to keep things level. I am surprised how just being off a little from being plumb level affects wind measurements I suppose due to the slight angle.
Joe Fitzwater
