Author Topic: Making Color Tables  (Read 7037 times)
Offline Farmtalk
  • Fitzweather
    • WV Waterfalls
Making Color Tables
« on: June 11, 2011, 08:56:08 AM »
Ok, I went ahead and made my actual color table, and got it finished. It is in a notepad document. However, I cant figure out how to put it into my radar. Can someone help me?
Thanks! :grin:
--farmtalk--
Joe Fitzwater
Chief Meteorologist for WVNS-TV 59 in Beckley, WV
Work Page on Facebook -> www.facebook.com/meteojoe
Work Page on Twitter -> https://twitter.com/meteojoe
Waterfalls -> www.wvfalls.com
Offline AWL
    • Ardmore Weather Live
Re: Making Color Tables
« Reply #1 on: June 11, 2011, 09:20:41 AM »
This is a very good explanation: http://www.wxforum.net/index.php?topic=5656.msg59320#msg59320
I created a folder within GR3 for my color tables. Place your tables there then just browse to that folder and pick a color table. This way I keep all my tables together.
1)  Copy
2)  Paste in Word or Notepad
3)  Save it as Youchoose.pal
4) Go into GR and go to view, set color table, and select what you saved.
« Last Edit: June 11, 2011, 09:30:36 AM by DougW »
Offline Farmtalk
  • Fitzweather
    • WV Waterfalls
« Reply #2 on: June 11, 2011, 09:40:30 AM »
Is there a program for .pal because I dont have it
Joe Fitzwater
Offline Farmtalk
  • Fitzweather
    • WV Waterfalls
« Reply #3 on: June 11, 2011, 10:02:44 AM »
Ok, I saved it as GR.pal (The whole thing as a title), but it isnt showing on the screen when I go to select the color table.....again though if .pal is a document type, then for some reason I dont have it.
Joe Fitzwater
Offline AWL
« Reply #4 on: June 11, 2011, 10:02:54 AM »
1)  Copy
Change your table from .txt to .pal
Offline Farmtalk
  • Fitzweather
    • WV Waterfalls
« Reply #5 on: June 11, 2011, 10:49:05 AM »
In notepad, all I have is *.txt and all files
In wordpress, I have *.doc, *.txt, *.rtf, and a couple more, but not .pal
Joe Fitzwater
Offline AWL
« Reply #6 on: June 11, 2011, 11:09:39 AM »
Save as...yourchoose.pal. Or...Move it to your gr3 folder as a text file then rename .pal....put it on your desk top as a text file then rename it to .pal then move it to your gr3 folder. Windows will complain you are changing the file type but go ahead and change it.
« Last Edit: June 11, 2011, 11:11:38 AM by DougW »
Offline Farmtalk
  • Fitzweather
    • WV Waterfalls
« Reply #7 on: June 11, 2011, 11:13:37 AM »
Again, not trying to be stubborn, but I dont have .pal at all.
Joe Fitzwater
Offline AWL
« Reply #8 on: June 11, 2011, 11:15:49 AM »
Ok....place the file on your desktop, backspace the .txt out and type in .pal The file is now renamed as a .pal then move it to your gr3 folder or where ever you want it to be.....
Offline Farmtalk
  • Fitzweather
    • WV Waterfalls
« Reply #9 on: June 11, 2011, 11:22:25 AM »
Let me make this clear: I have a computer IQ of 5 :roll:
I did what you did, but it still isnt showing as a .pal document, so it wont display in the GR3 folder.
Joe Fitzwater
Offline AWL
« Reply #10 on: June 11, 2011, 11:25:05 AM »
Would someone else chime in here.....please...
Offline Farmtalk
  • Fitzweather
    • WV Waterfalls
« Reply #11 on: June 11, 2011, 11:26:18 AM »
I'm sorry Doug. I dont mean to be so annoying....I'm just not very good at this :-(
Joe Fitzwater
Offline AWL
« Reply #12 on: June 11, 2011, 11:34:04 AM »
Ok...just for fun..open notepad. Don't type anything just go to "file"....'save as'...in the box titled file name..type 'gr7.pal'...and save to desktop. Now on your desk top you will have a new file that may show up as gr7.pal.txt. Right click...rename....back out the .txt and you have an empty .pal file(document).
.....Maybe I am explaining this all wrong...
« Last Edit: June 11, 2011, 11:46:37 AM by DougW »
Offline Farmtalk
  • Fitzweather
    • WV Waterfalls
« Reply #13 on: June 11, 2011, 11:50:45 AM »
The only thing you are confusing me with now is that when I right click to rename, it dosent show the file type, it just shows the title, in this case Color Table.
Joe Fitzwater
Offline Farmtalk
  • Fitzweather
    • WV Waterfalls
« Reply #14 on: June 11, 2011, 11:55:29 AM »
Never mind the last comment, I got it to work. I think that I only have one more problem: When I try to load the colortable, it shows a display that reads:
Error reading color table
Units not specified, expected 'Units:[DBZ,KTS]'
Do you know what I did wrong? Here is my file.
Joe Fitzwater
Offline Maumelle Weather
    • Maumelle Weather
« Reply #15 on: June 11, 2011, 12:05:27 PM »
Farmtalk,
I assume this is GR3.  All of my colortables do not have the brackets[] or KTS in it, just DBZ as the first line.
Units: DBZ
Try that and see what happens
Edit: Spelling, punctuation  #-o  Thanks Curly for pointing out the symbols, too.   :oops:
« Last Edit: June 11, 2011, 12:08:45 PM by sacreyweather »
GR2AE, GR3, Cumulus
Offline Farmtalk
  • Fitzweather
    • WV Waterfalls
« Reply #16 on: June 11, 2011, 12:25:59 PM »
Yes, it is GR3. I put "Units: DBZ", and it still does not read it.
Joe Fitzwater
    • Maumelle Weather
« Reply #17 on: June 11, 2011, 12:31:21 PM »
Okay,
I'm attaching one of the color tables I use.  GR3 should be able to use it.  If it sees it, you can modify it.
P.S. - This is a base reflectivity table.
GR2AE, GR3, Cumulus
Offline Farmtalk
  • Fitzweather
    • WV Waterfalls
« Reply #18 on: June 11, 2011, 12:45:56 PM »
What program can I open this with?
Joe Fitzwater
    • Maumelle Weather
« Reply #19 on: June 11, 2011, 12:47:53 PM »
To open the .zip you can use 7Zip, which is free at File Hippo.
GR2AE, GR3, Cumulus
Offline Farmtalk
  • Fitzweather
    • WV Waterfalls
« Reply #20 on: June 11, 2011, 12:49:35 PM »
I'll download it now and check it out. Thanks a lot! :grin:
Joe Fitzwater
Offline Farmtalk
  • Fitzweather
    • WV Waterfalls
« Reply #21 on: June 11, 2011, 12:53:43 PM »
I'm sorry....you can give up now if you want, but it wants to use adobe for some reason (Why?), but it wont open. I download 7zip, but I cant get it to use that program...
Could you copy the info in the file and display it here?
Joe Fitzwater
    • Maumelle Weather
« Reply #22 on: June 11, 2011, 12:56:41 PM »
Here ya go,
Units: DBZ
Step: 5
Color: 0 164 164 255 100 100 192
Color: 10 64 128 255 32 64 128
Color: 20 130 211 255 0 0 246
Color: 25 0 0 246 0 0 179
Color: 30 0 255 0 0 128 0
Color: 35 0 128 0 0 70 0
Color: 40 255 255 0 255 128 0
Color: 45 255 128 0 255 128 0
Color: 50 255 37 37 160 0 0
Color: 55 160 0 0 100 0 0
Color: 60 255 0 255 128 0 128
Color: 65 128 0 128 100 0 100
Color: 70 255 255 255 135 135 135
Color: 75 135 135 135 0 0 0
Color: 80 0 0 0 0 0 0
GR2AE, GR3, Cumulus
Offline Farmtalk
  • Fitzweather
    • WV Waterfalls
« Reply #23 on: June 11, 2011, 12:59:05 PM »
Thanks so much! I know I get pretty annoying because of my lack of computer skills...Thanks for waiting it out! :grin:
--Farmtalk--
PS: I got it to work....Ill be working on color tables all evening! :grin:
« Last Edit: June 11, 2011, 01:00:47 PM by farmtalk »
Joe Fitzwater
