Author Topic: weather34 template for weeWX  (Read 11229 times)
Offline taylormia
    • Merrifield Village
« on: October 08, 2018, 11:49:38 PM »
If anyone is interested in the weeWX adapted version of the weather34 template, you can find it at the link below courtesy of Ian Steeple. All support questions on this adapted version should be directed to Ian and not to Brian at weather34.
https://github.com/steepleian/weather34-Home-Weatherstation-Template-WeeWX-adapted
Here is my web site (https://weather.sathy.us) using this template. The additional benefit of this adapted template is the capability to display CanvasJS charts generated from native weeWX historical reports rather than a feed from the free Weather Underground API , which as many of you know is going away shortly.
Station: Davis Vantage Pro2 24hr FARS
Software: weeWX
Website: https://weather.sathy.us
Offline steepleian
    • The Claydons Community Weather
Re: weather34 template for weeWX
« Reply #1 on: October 09, 2018, 02:50:55 AM »
Thanks for the nod Taylormia :grin:
Here is a bit more background: -
I think that we can all agree that the real strengths of weeWX are what goes on 'under the hood (or the bonnet for a Brit like me)', its sheer adaptability and a huge community working out solutions together.
I came to weeWX after years of being a Cumulus user (another excellent software) but came to a grinding halt when changing to unsupported Weather Station. It was weeWX to the rescue along with the HP1000 driver and I was back up and running. In my Cumulus days I had been an early adopter of the excellent weather34 template, designed and owned by Brian Underdown. This was originally designed for use with Cumulus as a single dashboard concept where everything is accessible from a single web page. So could I use the template with weeWX, yes by deploying the CRT extension to generate a realtime.txt file.
Now I wanted it to do more, I am not a coder so it takes me a bit longer to discover the snippets of code that I need to make things happen and this is where this forum and others became a valuable resource for myself along with contributions and technical support from others. A big thanks here to David Marshall who has rescued me on more than one occasion.
Recently Brian Underwood took the decision to only support the Meteobridge version of his template going forward. However, he was very happy for the other versions of the template to hosted and maintained by others. On this basis, both the weeWX and Cumulus versions live on. I am now hosting the weeWX version and actively maintaining it in the spirit of Brian's original concept. You can find it here: -
https://github.com/steepleian/weather34-Home-Weatherstation-Template-weeWX-adapted
The latest version is now using the weeWX archive database to generate the pop-up CanvasJS charts instead of relying on Weather Underground. The setup guides are provided for general guidance only due to the multitude of ways weeWX can be setup by individual users.
I would like to re-iterate that although Brian Underdown is very happy for this version to exist and be maintained, he offers no support whatsoever for this version. Any requests to do so will remain unanswered. Please respect Brian's wishes in this respect. Any issues should be directed to this forum.
My own current version of the template shows additional features which may be included in future updates if there is sufficient demand. It can found here https://claydonsweather.org.uk
When used with a smartphone or a narrow browser window, the page morphs into a slimline mobile version.
Steepleian
« Last Edit: October 16, 2018, 01:46:52 AM by steepleian »
Offline taylormia
« Reply #2 on: October 16, 2018, 10:27:01 AM »
At the link below is a general guide on integrating weeWX weather software with the weather34 web template adapted for weeWX by Ian Steeple. In this example, the weeWX server and the web server are on separate systems. Download the guide to use the embedded web links.
https://github.com/steepleian/weather34-Home-Weatherstation-Template-WeeWX-adapted/blob/master/taylormia_remote_server_setup.pdf
« Last Edit: October 17, 2018, 10:52:34 PM by taylormia »
Software: weeWX
Offline Storm017
« Reply #3 on: October 29, 2018, 10:26:42 PM »
I'm trying to install the template (WE34-WE131018), but get the following error.
2018-10-28 18:59:39: (mod_fastcgi.c.2543) FastCGI-stderr: PHP message: PHP Warning:  include(): Failed opening 'version.php' for inclusion (include_path='.:/usr/share/php') in /var/www/html/settings.php on line 2
2018-10-28 18:59:39: (mod_fastcgi.c.2543) FastCGI-stderr: PHP message: PHP Notice:  Undefined variable: wver in /var/www/html/settings.php on line 27
Offline taylormia
« Reply #4 on: October 30, 2018, 01:52:14 AM »
When installing Apache and PHP, did you follow the guide referenced in Step 2 of my writeup.  Not sure if the reason is this but you may have not installed some PHP modules such as "php-curl" and "php-mbstring" .
Software: weeWX
Offline steepleian
« Reply #5 on: October 30, 2018, 06:20:43 AM »
Are your weeWX and webserver on the same computer or is the server at a remote location. Also what is the root of your webserver. If it is different to /html you will need to edit the skin.conf file.
Steepleian
Offline Storm017
« Reply #6 on: October 30, 2018, 07:41:01 AM »
Yes I did follow your write up.  I believe I have everything required installed...Will check this evening.
Offline Storm017
« Reply #7 on: October 30, 2018, 07:42:49 AM »
Steepleian
They are on the same computer.  Will check the ownership of the webserver this evening.
Offline Storm017
« Reply #8 on: October 30, 2018, 09:27:47 PM »
Steepleian
The root of the webserver is "var/www/html".  The ownership is pi:www-data and permissions are 0775. Going to reread the instructions taylormia provided.  Might of skipped something.
Offline Storm017
« Reply #9 on: October 30, 2018, 10:19:08 PM »
I was missing the php-mbstring.  I can go to the IP address and the template appears but does not populate with realtime data, but I'm still have the same errors:
2018-10-30 22:04:57: (mod_fastcgi.c.2543) FastCGI-stderr: PHP message: PHP Warning:  include(version.php): failed to open stream: No such file or directory in /var/www/html/settings.php on line 2
2018-10-30 22:04:57: (mod_fastcgi.c.2543) FastCGI-stderr: PHP message: PHP Warning:  include(): Failed opening 'version.php' for inclusion (include_path='.:/usr/share/php') in /var/www/html/settings.php on line 2
2018-10-30 22:04:57: (mod_fastcgi.c.2543) FastCGI-stderr: PHP message: PHP Notice:  Undefined variable: wver in /var/www/html/settings.php on line 27
The path match in both the Weewx config file and the settings1.php file.  The real time txt file does update.
Offline kc2kzz
    • Solitude Village Weather
« Reply #10 on: November 01, 2018, 10:14:03 AM »
Everything is working fine on mine except the daylight box.  Is there a specific setting I missed for that?
Offline taylormia
« Reply #11 on: November 03, 2018, 04:29:49 PM »
Looks like you are missing the "version.php" file in /var/www/html. Step 4d in my guide describes how this file is generated.
Software: weeWX
Offline kan6526
« Reply #12 on: November 23, 2018, 05:17:44 AM »
Chart blank
http://192.168.2.10/pws/chartswu/monthlytemperature.php
--------------------- /var/log/apache2/error.log ----------------------
 PHP Warning:  include(): Failed opening 'settings2.php' for inclusion (include_path='.:/usr/share/php') in /var/www/html/pws/settings.php on line 2, referer: http://192.168.2.10/pws/
PHP Warning:  include(settings2.php): failed to open stream: No such file or directory in /var/www/html/pws/settings.php on line 2, referer: http://192.168.2.10/pws/
PHP Notice:  Undefined variable: chartversion in /var/www/html/pws/chartswu/monthlytemperature.php on line 173, referer: http://192.168.2.10/pws/
Offline PaulMy
« Reply #13 on: November 23, 2018, 09:46:36 AM »
I don't have nor know weeWX but presume the 192.168.2.10 in your http://192.168.2.10/pws/chartswu/monthlytemperature.php is an IP address in your local network and not visible from outside.
For me the URL is http://www.komokaweather.com/pws/chartswu/monthlytemperature.php
Not sure where you would set that though in the weeWX version.
Enjoy,
« Last Edit: November 23, 2018, 09:48:25 AM by PaulMy »
Offline kan6526
« Reply #14 on: December 06, 2018, 06:10:27 AM »
WeeWX(3.8.2)
Hardware: WH2950
 Template Version: W34-WE(30 November 2018)
-----------------/var/log/apache2/error.log --------------
[Thu Dec 06 19:05:14.237736 2018] [:error] [pid 5387] [client 192.168.2.1:9460] PHP Notice:  Undefined variable: almanac in /var/www/html/pws/version.php on line 13
[Thu Dec 06 19:05:14.237822 2018] [:error] [pid 5387] [client 192.168.2.1:9460] PHP Notice:  Undefined variable: almanac in /var/www/html/pws/version.php on line 14
---------------/var/www/html/pws/version.php ---------------------------
<?php
$wver = "3.8.2";
$uptimedays = "8 days, 5 hours, 5 minutes";
$civrise = "$almanac(horizon=-6).sun(use_center=1).rise";     <---------line 13
$civset = "$almanac(horizon=-6).sun(use_center=1).set";     <----------line 14
Offline mteva
« Reply #15 on: December 06, 2018, 08:34:45 PM »
Hello, and sorry for my approximate english ;)
I'm trying to install your skin, I have:
- 1 single debian server 4.18.10-2
- Apache2 2.4.37-1
- weewx v3.8.2
I have W34-WX and 34-WE installed.
But I have a problem with the realtime.txt file
What do you think ?
Offline kan6526
« Reply #16 on: December 06, 2018, 08:55:33 PM »
Hi mteva
Your realtiem.txt has no data.
reference this
https://github.com/weewx/weewx/wiki/crt
Offline mteva
« Reply #17 on: December 06, 2018, 09:27:38 PM »
Thank you for the answer.
But where does the problem come from?
The extension does create the file, but the scrubbed data is wrong.
Offline kan6526
« Reply #18 on: December 06, 2018, 09:47:03 PM »
------------/var/log/syslog ---------------
Dec  6 14:31:23 debian9 weewx[24254]: crt: service version is 0.18
Dec  6 14:31:23 debian9 weewx[24254]: crt: output goes to /var/www/html/realtime.txt
Dec  6 14:31:23 debian9 weewx[24254]: crt: 'None' values will be displayed as NULL
Dec  6 14:31:23 debian9 weewx[24254]: crt: units will be displayed as US
Dec  6 14:31:23 debian9 weewx[24254]: crt: zambretti forecast: False
Dec  6 14:31:23 debian9 weewx[24254]: crt: binding is loop
--------------------weewx.conf --------------------------
# Options for extension 'crt'
[CumulusRealTime]
    filename = /var/www/html/realtime.txt
    unit_system = US
# options are US, METRIC, METRICWX
maybe, you can try reinstall weewx-crt
Offline GW400
    • Aadneram Fjellgrend
« Reply #19 on: February 10, 2019, 08:26:07 AM »
The url does not work any more
Offline GW400
« Reply #20 on: February 10, 2019, 08:27:48 AM »
Steepleian
Seems like the url is not working any more
Offline vreihen
  • El Niņo chaser
  • K2BIG
Offline balloon101
« Reply #22 on: March 13, 2019, 02:22:35 PM »
I am posting this in case it is an issue. I use installed weather34 template for weeWX on my raspberry pi. I did all the setup changes to get weewx charts working in the template but only todaybarometer.php was working. In looking at the url in the different php files I noticed on the charts that do not work there is ..// or ../ in front of weewx directory which is different than the todaybarometer.php. Removing the extra level change allowed all the charts to work. I followed all the latest install guides I could find but do not know why the url paths to the csv files have the extra level changes.
PS The template is a really nice, so I hope this posting will help someone.
Offline balloon101
« Reply #23 on: March 14, 2019, 12:19:02 AM »
One more issue I saw using the weewx version of the template. Seems the humidity does not display correctly in the nearby metar popup due to an incorrect line in metar34get.php The correct line is
$metar34humidity          = $parsed_json->{'data'}[0]->{'humidity'}->{'percent'};
Offline Russell797
    • Lowell Highlands Weather
« Reply #24 on: March 21, 2019, 11:24:33 PM »
balloon101
 :thumbsup:
Nice catch.
Also, I managed to figure out the issue with the charts not showing due to the " ../ " misprint, but only after some frustration. Wish I had seen your posts earlier. Funny how just one chart worked, the barometric pressure, as if it were a test or a puzzle meant to be solved! Gotta love it, right!  :grin:
« Last Edit: March 21, 2019, 11:29:07 PM by Russell797 »
Lowell Highlands Current Weather Conditions
