First, make sure the console clock is set correctly. If it is, disconnect the logger from the computer. Remove all power from the console including the batteries and remove the logger. Wait a few minutes. Reinstall the logger then power up the console. The console should beep 3 times when power is reapplied. Make sure the console clock is correct. Connect the logger to the computer and check for proper operation.
