Similar problem here with the RGR-968 gauge, after doing a transmitter swap it appears to be the gauge itself.
I suspect that moisture is getting into the exposed pcb (circuit board) so I cleaned it a little and dried it out with a hair dryer.
I and then sprayed and sealed it with an acrylic clear lacquer, remounted it and it has worked fine ever since !
Am running a WMR-968 for 3 years with VWS without much problem, antenna location is main difficulty as I have a lot of electronic gear near the console. Keep the antenna polarisation parallel - to the side, above and below are weakest transmission/reception areas.
