Weather Station Hardware > Ambient Weather and Ecowitt and other Fine Offset clones
Replacement parts for Ambient Weather WS-1001 Clone - Maplin N23DQ
Aircub:
Hi I have a Maplin Maplin Professional Solar Powered Wi-Fi Weather Station Code: N23DQ, which I believe is a clone of the Ambient Weather WS-1001.
http://www.maplin.co.uk/p/maplin-professional-solar-powered-wi-fi-weather-station-n23dq
Recently the outside temperature overhead by about 10 degrees when the humidity is high, when its dry it goes back to normal, is it possible to replace the temperature sensor on the outside unit.?
dupreezd:
Seem my post here
http://www.wxforum.net/index.php?topic=30689.new#new
Aircub:
Thanks will take a look at the sensors when I get a free moment.
Rychu:
--- Quote from: Aircub on May 29, 2017, 03:33:38 AM ---(...) is it possible to replace the temperature sensor on the outside unit.?
--- End quote ---
Both stations use WH24 and WH24A (external) and WH25 and WH25A (internal) sensors - both are interchangeable. Important to be configured for the same frequency of 433 MHz or 866 MHz or 915 MHz. Typically, the sensors carry all three bands simultaneously.
thereaper:
mine doesnt its a sht31 package temp/humidity and its a maplin N23DQ
http://www.ebay.co.uk/itm/SENSIRION-SHT31-DIS-B-Humidity-Sensor-2-3-3-V-0-to-100-Relative-Hum-/172196302822?epid=1467966912&hash=item2817b30fe6:g:OdMAAOSwYmZXLMMe
[#] Next page
