Author Topic: Point Forecast Down?  (Read 5950 times)
Offline mkutche
    • GosportWx.com
« on: February 18, 2018, 07:58:12 AM »
Is it just down or is it down for good??
https://prnt.sc/igdtuk
Mike K.
Davis Vantage Vue 6250 - CumulusMX (3.21.1-b3205)
Gosport, Indiana
Gosportwx.com twitter.com/GosportINWX
Offline ValentineWeather
Re: Point Forecast Down?
« Reply #1 on: February 18, 2018, 08:02:08 AM »
Older version advforcast2 (2015) went over to zone this morning so switched to newer version (2017). I don't like the newer because new api address is so unreliable its down more than the older.
I just switch back and forth when I catch issues.
Randy
Offline mkutche
    • GosportWx.com
« Reply #2 on: February 18, 2018, 08:18:47 AM »
I guess it was on NWS's side it's working right again.
Mike K.
Gosport, Indiana
« Reply #3 on: February 18, 2018, 08:35:56 AM »
Not sure what version you are running but the older version has less issues for me. The new API address for my region is very unreliable. Ken posted link as text file for older version here.
https://saratoga-weather.org/advforecast2-V4.02.php?sce=view
I just keep both versions seperate folders and when one goes down switch to the other.
Randy
Offline mkutche
    • GosportWx.com
« Reply #4 on: February 21, 2018, 10:18:22 AM »
I tried both 2015 and 2017 update and still the forecast is down. Ok I did a force update on the 2015 version hopefully it won't break again.
« Last Edit: February 21, 2018, 10:25:32 AM by mkutche »
Mike K.
Gosport, Indiana
« Reply #5 on: February 21, 2018, 10:59:50 AM »
I am getting some very old forecasts from almost a year ago.
Offline CNYWeather
    • CNYWeather
« Reply #6 on: February 21, 2018, 12:20:03 PM »
I just went back to 4.02 version. The v5.04 seemed pretty sketchy on mine and everyone else's sites.
Tony
« Reply #7 on: February 22, 2018, 01:34:20 AM »
Darn, neither version works for me.  Seldom have I seen it this bad.
« Last Edit: February 22, 2018, 02:02:11 AM by Bunty »
Offline gwwilk
  • Southeast Lincoln Weather
« Reply #8 on: February 22, 2018, 08:41:21 AM »
My forecasts are also a mess either way!  The Omaha office is the culprit, whereas the Hastings office seems to be OK.
Regards, Jerry Wilkins
gwwilk@gmail.com
Offline satcop
    • Clifton Virginia Weather
« Reply #9 on: February 22, 2018, 08:45:42 AM »
Haven't had problems with getting the cast in the past as much as I have seen others have seemed to.  But it seems that this time it has hit here too (Sterling VA).   No updated forecasts since Tuesday evening, something clearly broke, did they change urls?  Update:  Note forcing it to provide a zone forecast gets one, so this definitely appears to be associated with the point forecast.
« Last Edit: February 22, 2018, 09:30:38 AM by satcop »
Clifton, Virginia Weather
Blitzortung Stations 1189, 1451 - CWOP EW1675
« Reply #10 on: February 22, 2018, 08:57:06 AM »
I'm back on the 2015 version starting early yesterday when 2017 had no forecast at all (just missing with a message unavailable). At least older version defaults to zone most times.
Regional office is North Platte.
Randy
Offline metzeric
    • www.niagaracountyweatherwire.com
« Reply #11 on: February 22, 2018, 09:04:02 AM »
i Went back to the 4.02 version yesterday    however now nothing as updated since yesterday morning and im still stuck on the Wednesday forecast
Offline DaculaWeather
    • North Georgia Weather
« Reply #12 on: February 22, 2018, 09:05:39 AM »
Stuck here too...
« Reply #13 on: February 22, 2018, 11:56:24 AM »
Dacula, you're still running advforecast2.php (JSON) - V5.04 - 11-Oct-2017 on PHP 5.5.38
Maybe it's time to go back to the 4.02 script for advforecast2.php until the NWS gets it together again with api.weather.gov.
« Reply #14 on: February 22, 2018, 11:59:27 AM »
I may do that Ken. I sent them an email today and even pointed them to this thread. I haven't heard back yet but I expect to before the end of the day.
It gets to be a pain to switch back and forth since I end up customizing things so much.  :grin:
Offline metzeric
« Reply #15 on: February 22, 2018, 12:08:02 PM »
i am now on 4.02  and it didnt change a thing for me :(
« Reply #16 on: February 22, 2018, 12:08:17 PM »
I'm going to try (again) contacting the NWS to see what their plans are for api.weather.gov/forecast-v3.weather.gov.
My last missive went unresponded :(
« Reply #17 on: February 22, 2018, 12:12:24 PM »
metzeric, your issue seems to be with your web server.. it is getting
<!-- advforecast2.php (multi) - V4.02 - 07-Nov-2015 -->
<!-- NWS URL: https://forecast.weather.gov/MapClick.php?lat=43.3476&lon=-78.5559&unit=0&lg=english&FcstType=text&TextType=2 -->
<!-- zone=NYZ001 -->
<!-- Network error: php_network_getaddresses: getaddrinfo failed: Name or service not known (0) -->
<!-- loading https://forecast.weather.gov/MapClick.php?lat=43.3476&lon=-78.5559&unit=0&lg=english&FcstType=text&TextType=2 - 7895 bytes -->
It appears the name lookup for forecast.weather.gov is failing, and that is a web hoster issue.. call tech support for them and ask them to fix the DNS lookup issue.
« Reply #18 on: February 22, 2018, 12:14:31 PM »
I was getting these errors earlier.
« Reply #19 on: February 22, 2018, 12:17:35 PM »
Seems to working now.
« Reply #20 on: February 22, 2018, 12:17:53 PM »
And now that same forecast is working... go figure.
Offline satcop
« Reply #21 on: February 22, 2018, 12:19:42 PM »
Working here again as well (out of offices lwx akq fcx), which were not before, so maybe someone fed the hamsters powering the computers at nws. ](*,)
« Last Edit: February 22, 2018, 12:40:20 PM by satcop »
« Reply #22 on: February 22, 2018, 12:21:10 PM »
Just got this message back
Hi Steve,
Thanks!  I've opened up a ticket with the appropriate folks to get it looked it.  Seems kind of odd - see the errors with points in FFC's and GSP's area, but not BMX's, even though point-and-click shows things are up to date.
Steve L.
NWS Peachtree City, GA
Offline metzeric
« Reply #23 on: February 22, 2018, 01:07:52 PM »
ken what is the you are using that shows the dns error  so  i can tell godaddy??
« Reply #24 on: February 22, 2018, 01:09:04 PM »
Right click on the page with the error and view source.
