Author Topic: Run Saratoga ajax-dashboard as a CRON job  (Read 2248 times)
Offline griffo42
    • Carina Weather
« on: December 14, 2014, 10:48:06 PM »
Hi
Is there any problem in running the SARATOGA WEATHER ajax-dashboard.php program as a solo CRON job on my web server?  I have included in this program code to extract various timely (5 min) data and so update a MySQL database.  I need to update that database in a timely manner (say 5 min intervals).  At the moment it updates the database whenever someone logs on to my website as doing just that causes the ajax-dashboard.php to run.
One obvious solution would be to update the database by using another program outside the ajax.........php however, as yet, I haven't worked out how to input the 5 min data into a program in useable form.
Any suggestions please?
Keith Griffin
https://www.kstwx.net/index.php
Davis Vantage Pro2 Model #6152AU
Cumulus latest version
Saratoga Weather World template Cumulus plugin
Carina Weather, Brisbane.
Offline wvdkuil
  • Wim van der kuil
Re: Run Saratoga ajax-dashboard as a CRON job
« Reply #1 on: December 15, 2014, 02:48:57 AM »
Hi
Keith Griffin
I use cron for a similar reason,  index.php runs on set intervals using cron.
I attached the script, it is set to run the index.php startpage.
The ob_start and ob_clean functions suppress all output.
So make a testrun first with http://www.kstwx.net/example_cron.php?debug
All output will be shown normally and you can check if all is OK.
Set the cron to run without ?debug.
Some  minor "problems":
  • your visitor counters will be affected with all those cronjobs, you can use the $cron_job variable to test in your scripts if the visitor should be counted
  • your 5 minutes database-load interval will be affected by the normal visitors as long as you do not check that also in the scripts
Success, Wim
