Administration => WXForum Bugs/Suggestions => Topic started by: W3DRM on June 19, 2015, 11:16:38 PM
Okay, there must be some setting that I've inadvertently changed or something has changed on the forum.
Every post and/or message I have made in the past month or so has double vertical spacing between each paragraph. When I do a Preview before sending I see the double spacing. If I click on the "Toggle View" button in the upper section of the screen, I then can edit the extra lines from my text but this is such a pain.
Is there any setting that will prevent the extra vertical space from being generated. For this post, I am not removing the extra spaces so you can see what I mean.
Thanks for the help!
That is strange, Don. I'm not aware of any specific setting that calls for double-space on lines.
Are you using the default font face, font size in the editor?
Yes, I deliberately double-spaced the above two.
This line is just below the prior line.
