If it was me no way I would leave the anemometer over the gauge. I would move it at least 90 degrees and go to page 27 of manual and calibrate the offset.
Or separate the ISS from the anemometer.
Concur. First choice, separate the two, put the ISS on the ground (
within important guidelines), and leave the anny high. Two, leave them together, but if you're going to re-calibrate, might as well go 180 degrees out for best clearance over the bucket.
