Like to help out with hosting costs for WXForum.net? Use the donate page. Thanks!
Yes, easy if you install the wee-wd extension!Running here http://www.sanfordweather.com/pws/
I installed Brian's template in /mysiteRoot/pws and the clientraw from the wee-wd is in the default location of /mysiteRoot/WDWhen you config HWS just point it to http::/mysiteRoot/WD/clientraw.txt as the path to data file, in my case it's http://sanfordweather.com/WD/clientraw.txt
