Author Topic: Sample Code for extended loop image slide shows  (Read 8104 times)
Offline TNETWeather
  • Kevin Reed (KrelvinAZ)
  • Davis Vantage Pro2+ with full FARS
Re: Sample Code for extended loop image slide shows
« Reply #25 on: September 04, 2011, 05:23:13 PM »
The biggest hold up is a lack of schedule trigger.
With the huge variation or complete lack of cron abilities of many hosts (some only have once an hour as the minimum interval, others like E-Rice have none), I have not come up with a solid easy to support method of doing this.
Ideally, there would be a simple easy to setup, inexpensive win tool you could use that you could point to the website and a specific php script and set the timing interval to what you want and be done.
Setting up a task scheduler is difficult to support especially for people who have never done that before.
So while the scripts themselves for displaying the info are basically easy to provide, without an easy to use trigger that is easy to support it is hard to release.
I actually wrote a small Win utility to do this, but it needs a bit more work and I have no time to work on it.
All you need is Time, Aptitude and Desire ... and you can build just about anything...
Offline jmcmurry
  • Jim McMurry
    • Juneau County Weather
« Reply #26 on: September 04, 2011, 06:14:51 PM »
System Scheduler (free) http://www.splinterware.com/products/wincron.htm is easy to use and I use it in just that way because I'm with e-rice.  I believe many others use it too.
- Jim
Offline TNETWeather
« Reply #27 on: September 04, 2011, 06:35:01 PM »
I've looked at it.  If the user is not logged in, it doesn't work.  The Paid version supports that but is $30
Offline Strgazr27
  • "The Cam Man"
    • Kings Park Weather
« Reply #28 on: September 09, 2011, 07:45:38 PM »
Kevin,
Fully understand your crazy busy but any updates? Would LOVE to add this to my site.
Thanks!
Bobby M.
Davis VP2 6152 w Daylight FARS - Logitech C525 and C310
WD - WDLive - GRLevel3 - Image Salsa - VVP - Startwatch
"http://www.kingsparkweather.com"
KNYKINGS7 on WU
Offline weatherc
« Reply #29 on: September 10, 2011, 07:35:48 PM »
For things like this i use a simple SystemSheduler + VBS-script what call the file on server.
Once first is set up it is damn easy to replicate to other calls.  :grin:
