Author Topic: Cheap Alternative Davis Mounting for Metal Roof  (Read 12288 times)
« on: June 16, 2009, 05:07:22 PM »
I was hesitant to  use a tripod mount on my metal roof, so I fabbed up a mount for about $25 bucks.  The nice thing about it is no chance of water leaks, the whole system pivots down to deck level for maintenance and it was cheap.
Materials:
Sat dish J-mount - $9
8 ft length 1 1/4" T6061 pole - $16
Thin metal for shim (I had some rolled plashing made of some sort of tin/lead that worked perfectly.  I think a person could use thin aluminum as well) - free
Assembly:
Simple really.  Remove the bracket off the J mount and install by predrilling holes and lagging to beam. They could go on a gable, or in my case a protruding ridge beam.  Shim the tube and jam it into the J arm.    Mount the weather gear on the arm.  Drag it up the ladder and  install the arm to the base mount.  BTW, I did this with no assistant so it took a bit longer.  If you had a person on the roof it could be a 10 minute job.
End Result:
I mounted the anemometer higher than the bucket so that if I wanted to I could climb up to service the bucket and ISS. Now I can remove the bottom pin and pivot the whole thing for service.  Seems to work right through my metal  roof - 100% transmission.  :)
Offline DanS
  • Chiang Mai weather
    • ThaiWx
Re: Cheap Alternative Davis Mounting for Metal Roof
« Reply #1 on: June 16, 2009, 05:16:20 PM »
Nice job!! Great idea especially for those of us getting up there in the years and hesitant in getting up there on the roof! :grin:
Offline mcneese832000
    • Gumbeaux Weather
« Reply #2 on: October 04, 2010, 09:27:14 PM »
Where did you get the j-mount at?
Davis Vantage Vue w/ Weatherlink IP
http://www.weatherlink.com/user/gumbeaux
    • Gumbeaux Weather
« Reply #3 on: October 04, 2010, 09:50:42 PM »
also, did you jam the pipe that the station is on into the j-arm? I am trying to do the same thing you did. It is a great idea.
« Reply #4 on: October 04, 2010, 09:55:14 PM »
Bought the J-arm at a satellite store.  Cost about 10 bucks.  And yes, I shimmed and jammed it in.  I should have added a set screw, but it is really tight.
Offline Barry Curtis
  • "Three WX Stations and Counting...LOL!"
« Reply #5 on: October 05, 2010, 02:47:59 AM »
I'm going to make this...looks great.  I'm going to use some self-tapping hex head screws to hold pole into the j-pipe to keep it from moving.  The only thing that worries me is it going to be stable as all that is holding it is the bracket. 8 Feet of pipe sticking up seems like a lot...will check it out.
« Reply #6 on: October 05, 2010, 03:06:21 AM »
Oh, yeah; almost forgot.  You said you remove the pin to pivot it down...  I used to install satellite and the j-arm uses a self-tapping screw on each side of the arm to hold it from pivoting down. Did you drill it out and install a pin? Sounds like a great idea.  I'm going to Home Depot tomorrow and get some 1 1/2" rigid to make this.Thanks for the idea...Barry.
« Reply #7 on: October 05, 2010, 08:58:25 AM »
Pin was the wrong word.  This particular J arm uses a bolt with lock nut to keep it up.  There is a pin that I installed as backup.  Pull that and loosen the locknut and it then pivots down.  Be aware that the rain bucket screen might come out when you pivot it down.
I am really happy with this mount system; has handled 40-50 mph winds no problem.
Offline kray1000
  • Purveyor of wry
« Reply #8 on: October 05, 2010, 09:04:10 AM »
Would the rain gauge record some rainfall when you're doing this?
Offline DaculaWeather
    • North Georgia Weather
« Reply #9 on: October 05, 2010, 11:47:05 AM »
Not if you put the VP console into setup mode before you start.
Love those J mounts, very versatile  :grin:
Good to know!
« Reply #10 on: October 07, 2010, 01:36:00 AM »
Would really be funny if the rain guage was clogged up and had a 4" rain the night before you lowered it to work on it...LMAO!
Offline KeithBC
« Reply #11 on: October 07, 2010, 10:37:08 AM »
I think that would be "when", not "if"!  The only time you know it's clogged is after you've had a 4" rain and it reads zero.  I'd think SOP for that mounting would be to stand well to the side when you lower it.
Offline AjaxKnights29
    • Ajax Weather
« Reply #12 on: May 25, 2015, 09:23:55 PM »
Materials:
Assembly:
End Result:
Does it sway in the wind?
« Reply #13 on: May 26, 2015, 11:53:02 AM »
Not enough to create false rain bucket tips.  Winds to 80-90 kph.
