Author Topic: Νew La-crosse ws 2800 - ws 2810  (Read 19463 times)
Offline wuhu_software
    • WUHU Software Yahoo Group
Re: Νew La-crosse ws 2800 - ws 2810
« Reply #25 on: December 25, 2009, 08:39:10 AM »
Another user reported it was found here:
C:\Documents and Settings\All Users\Application Data\currdat.Lst
Offline DanS
  • Chiang Mai weather
    • ThaiWx
« Reply #26 on: December 25, 2009, 08:57:19 AM »
Just found it the last place you mentioned  C;\Documents and Settings\All Users\Application Data\currdat.lst.    Looking at it's properties doesn't show it as hidden but running a search for it doesn't show it's there. Anyway, I put that path and filename in and WuHu sees it and updates. Data fields filled in too. Now the window just won't minimize for some reason but I can live with that.
    • Watts Bar Weather
« Reply #27 on: December 25, 2009, 09:00:50 AM »
Picky picky picky!   [-X
Offline DanS
    • ThaiWx
« Reply #28 on: December 25, 2009, 09:09:55 AM »
I think there's a conflict somewhere between the two WUHU applications running at the same time. I stopped the 2310's program and the 2810 will now minimize. restarting the 2310 now and it's coming back fine. Just minimized it along side the 2810 so both are running and happy (for now). Just have to bring 'em up in order I guess. :-k I'll pick at them and maybe over time can "fine tune" them but for now they're both running. Thank you wuhu_software and Merry Christmas!
Dan
edit: .. and thank you too Greg. It's the antagonizing that makes me want to try harder. :lol: ;)
« Last Edit: December 25, 2009, 09:12:30 AM by DanS »
    • Watts Bar Weather
« Reply #29 on: December 25, 2009, 09:42:26 AM »
I can't find it now but you can put a startup delay in the ini file for the 2310.  Perhaps that would fix things for you.
Offline DanS
    • ThaiWx
« Reply #30 on: December 26, 2009, 10:21:12 AM »
Thanks Greg.  Appreciate the PM showing that you can add a line in the C:\Program Files\WUHU\WUHU Configuration Data file to delay starting and give time for other programs to start first. (thought I should mention this to show that this problem is resolved).  :grin:
