Mark, I’ve given the sensors over two hours. The three sensors have settled into their own respective humidity values. Anthony, you’ve obviously answered the question why and now that you’ve explained it, I realize the values have been remarkably constant. Thank you both (and everyone) for your feedback.
The original indoor sensor is at 21%, the new THGN123N is at 36%, and the original THGR968 is 56%. (And this likely also tells me who might be using similar OS temperature sensors in the area at this low temp.)
The temperature outside is 0.32F for the indoor BTHR968 sensor and the new THGN123N. The THGR968 is reading 1.22.
Okay, so, if I understand correctly, the humidity will default to the current values for each sensor when the temperature drops below 14F. This means my dew point calculations will be invalid.
Now, as regards the temperature. All three have lithium batteries, the THGR968 likely the oldest and the THGN123N the newest. With two of three matching, it appears the original THGR968 is 0.72F high.
I currently live in Malone, NY, just south of the Canadian border between Montreal and Lake Placid. The general area has records to around -60F and I’ve recorded near -30F myself in recent years with the THGR968. I'm guessing that we'll see well below -30F this winter.
The new THGN123N says spec supports to -40F and while the OS and RS manuals say -4F for the THGR968, it is often advertised to support to-58F. I’ve read some discussion about whether this -58F value was a typo or not. (The manual talks about lithium batteries working to -58F so that might be the source of that figure.) Maybe the batteries become the limiting factor more so than the sensor?
I’m happy with the WMR968 and don’t have the budget for anything more serious at the moment. In the process of switching from FreeWX-WI 1.02 beta to Virtual Weather Station v14 (p103). I just bought the THGN123N because it was an inexpensive add-on that might give more range on cold days (and I was concerned over errors I was getting, though I have to admit I hadn’t read enough to realize the problem was because of humidity at the low temp).
Aside from the apparent 0.72F discrepancy by the THGR968, I don’t have any observed problem (and I don’t know the impact of battery age, nor if the amount of discrepancy varies at colder or warmer temps), or, for that matter, if maybe the other two sensors or even all three are in error.
Anyway, would anyone care to share an opinion about whether the THGN123N is value-added or unnecessary?
