Okay, so I have an Acurite 5-in-1 with the Smarthub and I got to feeling jilted by Acurite, so I went looking for a way to make my system start working again. I discovered the MeteoBridge solution to use the TPLink DIR-505 to intercept the Smarthub packets.
I got the 505 flashed and am able to bring it up with it wired to my network. I can configure everything fine and save it. But, when I pull the ethernet cable and reboot it, the 505 doesn't connect with my wireless router at all. I've tried every possible configuration on the 505 and on my router's wifi settings.
I've tried running both on WPA, WPA2. I've tried using an USB stick to have the 505 boot from an image (although I'm not sure I have good instructions for that). Can anybody give me some help or relate their experience getting this kind of setup going?
Thanks!
