resetting and re-syncing 2 different things. I was referring to re-syncing. This is were you take ALL batteries out of ALL sensors/display. Basically going back to the day you installed the unit. I mentioned the distance, because Lacrosse seems to over state what their stations will do, plus when you factor in walls and such.
The fact that your problem seems to be wind sensor specific, if all the above fail, you may have a real issue with the sensor itself. I know in the past some of the 2810 units experienced serious moisture leakage. If that's the case and it's still under warranty, try calling Lacrosse,
'Good Luck!
