Author Topic: nws-alerts.php V1.43 with Leaflet/OpenStreetMap now available  (Read 1727 times)
I've updated Curly's nws-alerts V1.42 package to use Leaflet/OpenStreetMaps instead of Google maps, so no API key is needed anymore.  Support for optional Mapbox.com API key is provided.
The Saratoga Base-USA template was updated, so use the update tool with a query of Base-USA, Plugin-*, 14-May-2019.
The standalone script set was also updated on the legacy scripts page and I've attached a small zip with the changed files.  (note that nws-alerts.php V1.43 is only a version rev from V1.42).
Also the full script set is available on my GitHub distribution
« Last Edit: May 15, 2019, 11:27:20 AM by saratogaWX »
Online wvdkuil
  • Wim van der kuil
Re: nws-alerts.php V1.43 with Leaflet/OpenStreetMap now available
« Reply #1 on: May 14, 2019, 12:23:07 PM »
As always, thanks  [tup]
Wim
Offline gwwilk
  • Southeast Lincoln Weather
« Reply #2 on: May 15, 2019, 12:30:08 AM »
Great job, as usual!  Thanks, Ken. [tup] =D>
Regards, Jerry Wilkins
gwwilk@gmail.com
Offline gwwilk
« Reply #3 on: May 15, 2019, 08:45:04 AM »
A little glitch here with xhtml validation.
There's probably a simple fix, but it's beyond my ken, Ken.  :-)
gwwilk@gmail.com
« Reply #4 on: May 15, 2019, 10:47:55 AM »
Ahh.. the validator was parsing the HTML inside the <script>...</script>
I've added
<script>
// <![CDATA[
</script>
to have the parser stop trying to do that and become annoyed :)
Try the attached replacement.
« Reply #5 on: May 15, 2019, 10:59:50 AM »
I've pushed that change to the Base-USA template, the Legacy-scripts and the GitHub distributions.  Thanks for spotting that omission.
Offline txweather.org
    • Texas Weather
« Reply #6 on: May 15, 2019, 11:09:25 AM »
Thanks Ken!
Offline gwwilk
« Reply #7 on: May 15, 2019, 11:12:53 AM »
I had already corrected another little glitch with this addition of 'type' to the javascript call:
$leafletScript = '<script src="https://cdnjs.cloudflare.com/ajax/libs/leaflet/1.0.3/leaflet.js" type="text/javascript"></script>'."\n";Again the validator for xhtml complained about this omission which is useless these days, really.
Thanks, Ken!  I had no idea what to do, but the CDATA exclusion is perfect.
gwwilk@gmail.com
Offline Jasiu
    • LexMAWeather
« Reply #8 on: May 15, 2019, 11:19:59 AM »
Yup. And it is no longer necessary in HTML5.
https://lexmaweather.info
« Reply #9 on: May 15, 2019, 11:26:33 AM »
Ahh... for XHTML, it's needed.  HTML5 not needed.  Since the templates use XHTML 1.0 Transitional, I've added that to the script.. thanks again.
BTW, it was an interesting challenge to modify Curly's original Google map script to do Leaflet instead .. a bit of somewhat convoluted PHP to generate the inline script only if the alert had geo-coordinates present, and quite a change in the generated JavaScript to control Leaflet due to differently named/accessed Leaflet functions v.s. Google maps functions.
Posted in the usual places...
Offline tmabell
    • Mishawaka Weather
« Reply #10 on: May 21, 2019, 08:22:00 AM »
Quick question Ken, doe the latest version still support "Filtered Events" or was that feature removed?  I ask because I did not see the necessary files in your GitHub distribution package.
« Last Edit: May 21, 2019, 08:23:43 AM by tmabell »
« Reply #11 on: May 21, 2019, 10:34:19 AM »
All the filtering features from Curly's 1.42 version are still there .. I only replaced the Google map with the Leaflet map generation.
What was missing in the GitHub package??  I may have skipped something when packaging it for GitHub.
Offline tmabell
    • Mishawaka Weather
« Reply #12 on: May 21, 2019, 10:52:27 AM »
If you need these file I will forward them to you but these are needed in order to configure the filters:
nws-alerts-events.php
nws-alerts-filter-config.php
nws-alerts-filtering.php
Thank you for keeping these old scripts alive!
Offline mldenison
    • York, PA Weather
« Reply #13 on: May 21, 2019, 10:54:56 AM »
Hey Ken,
The new version is working fine on my PC.
The 'check-fetch-times.php' has an 'unknown' for 'nws-alerts.css':
Windows 7 x64
Weather PC: Intel NUC
Davis Vantage Pro 2
Weather Underground: KPAYORK30
York, PA Weather (Saratoga)
York, PA Weather (Leuven)
York, PA PWS Station
« Reply #14 on: May 21, 2019, 11:09:04 AM »
Yes, please .zip and send me those files... I see the .zip and GitHub only have ./cache/nws-alerts-filters.php in it.. the other files you cited are not there.
« Reply #15 on: May 21, 2019, 11:10:13 AM »
Hey Ken,
I'll check.. I think maybe the versioning info is not in the CSS file.  Thanks...
« Reply #16 on: May 21, 2019, 12:34:19 PM »
Hey Ken,
Ahh... I discovered there was some missing code to have the .css files version info included in the version-list.  I've updated that (and check-fetch-times.php V1.27 also) so the versioning on .css scripts needed are now included in the display.
Pushed Version 3.292 - 21-May-2019 (Base-*) updated check-fetch-times.php V1.27 for .css file version checking
Offline mldenison
    • York, PA Weather
« Reply #17 on: May 21, 2019, 01:21:01 PM »
Works great, Ken.  Thanks for the quick update!
Windows 7 x64
Davis Vantage Pro 2
Offline mikeym2m
    • MikeyM's Thornhurst PA Weather
« Reply #18 on: May 24, 2019, 09:16:00 AM »
Thanks Ken
Worked Great last night with the "Special Weather Statement", "Severe Thunderstorm Warning" and "Tornado Warning" all showing correctly.  [tup]
Cheers
MikeyM
Offline tshattuck
    • Your Local Weather - Clay, NY
« Reply #19 on: May 27, 2019, 11:12:16 AM »
Ken:
I noticed in your posts here you mention MapBox is optional. I don't have an API Key for MapBox what happens if I don't have API key?
Offline Otis
  • (aka Paul)
    • Lake Huron Weather
« Reply #20 on: May 27, 2019, 11:46:33 AM »
I believe it just eliminates the mapbox map display options like satellite.  I don't think it will effect the performance of the script.
CW3699
Offline Jasiu
    • LexMAWeather
« Reply #21 on: May 27, 2019, 12:23:44 PM »
Ken:
The default behavior is to use the Esri_WorldTopoMap, tiles which needs no key. You only need the Mapbox key if you want to use Mapbox tiles.
Offline tshattuck
« Reply #22 on: May 27, 2019, 08:27:37 PM »
I will go without the API Key based on your comments. I want to keep it simple.
Thanks for the feedback.
Offline Otis
  • (aka Paul)
« Reply #23 on: May 27, 2019, 09:23:27 PM »
Just to be clear, I never said not to get the API Key, just that you don't need one for the script.
I do have one, the key.
CW3699
Offline mldenison
    • York, PA Weather
« Reply #24 on: May 27, 2019, 09:38:06 PM »
I added my (unused) mapbox api key.  Everything still looks the same.  Anybody want to share a link to their page that uses mapbox?  Thanks.
Windows 7 x64
Davis Vantage Pro 2
