Author Topic: ALERT: Geomagnetic K-index of 7 (G3)  (Read 1502 times)
« on: March 17, 2015, 10:06:51 AM »
Space Weather Message Code: ALTK07
Serial Number: 90
Issue Time: 2015 Mar 17 1334 UTC
Threshold Reached: 2015 Mar 17 1330 UTC
Synoptic Period: 1200-1500 UTC
Active Warning: Yes
NOAA Scale: G3 - Strong
NOAA Space Weather Scale descriptions can be found at
www.swpc.noaa.gov/noaa-scales-explanation
Potential Impacts: Area of impact primarily poleward of 50 degrees Geomagnetic Latitude.
Induced Currents - Power system voltage irregularities possible, false alarms may be triggered on some protection devices.
Spacecraft - Systems may experience surface charging; increased drag on low Earth-orbit satellites and orientation problems may occur.
Navigation - Intermittent satellite navigation (GPS) problems, including loss-of-lock and increased range error may occur.
Radio - HF (high frequency) radio may be intermittent.
Aurora - Aurora may be seen as low as Pennsylvania to Iowa to Oregon.
This might be an opportunity for Aurora viewing and whistler listening...
Offline BigOkie
  • Tulsa, OK
    • KOKTULSA13
Re: ALERT: Geomagnetic K-index of 7 (G3)
« Reply #1 on: March 17, 2015, 09:01:58 PM »
Serial Number: 90
Active Warning: Yes
And no drone/multicopter flying, especially those that rely on GPS for position fixes and the like.  K-index right now is 7 and I saw 8 earlier.  Given that it's just two days from the vernal equinox I'm not surprised that we're seeing/hearing terrestrial noise.  Satellite reception will get hammered for the next week or so.
Weather radios:
Reecom R-1650
Sangean CL-100
Uniden Home Patrol I
Offline ValentineWeather
« Reply #2 on: June 24, 2015, 06:17:59 PM »
Forecast tonight for aurora borealis down to red line.
Randy
Offline Scalphunter
« Reply #3 on: June 27, 2015, 02:32:36 PM »
No aurora  here till late August so you lower 48 peeps enjoy them.
