The New record High/Low function ONLY works with the Weather Undergrounds records and for some reason, the tags are using the average high and low for ONLY SOME people. The tags are correct, the code is correct but the results are wrong. The only answer is to simply DISABLE the high and low records option at the top of the script. Simply set it to flase and the flag goes away. I've looked at the code on those that have the problem and its no different then the code that works. I can find no differences anywhere. Sorry guys, some things just can't be explained with what we can see in Weather Display.
Scott
