Author Topic: weather34 PurpleAir **solved**  (Read 724 times)
Offline txweather.org
    • Texas Weather
« on: March 20, 2019, 02:50:29 PM »
Team,
I could not make the station ID work using the template setup page.
Instead I had to insert manual data to the purpleair.txt file to be able to display the correct station otherwise it kept using the default template output.
Any ideas why this is happening?
Right now I am testing with a station id near me. I will have my own soon.
« Last Edit: March 24, 2019, 06:01:40 AM by docbee »
Re: weather34 PurpleAir
« Reply #1 on: March 20, 2019, 07:20:56 PM »
You're running Brian's   Meteobridge HWS version (MB-UB40-EDS)  MB TP-Link-(3.9-12717).  I'm moving this to the Meteobridge board .. you may need to update some scripts.  If you do, use Brian's official distribution at https://github.com/weather34/Meteobridge-Weather34-Template for the source.
Best regards,
Ken (keeper of the CU-HWS version)
    • Texas Weather
« Reply #2 on: March 20, 2019, 08:54:28 PM »
Thanks SaratogaWX, Thats the one I am using... I just did a pull to see if I had any updates and nothing. Still the same issue. :(
    • Texas Weather
« Reply #3 on: March 20, 2019, 10:55:43 PM »
One thing I found is that my meteobridge http services are failing: HTTP Upload:   2019-03-20 21:52:51 Sent: 2019-03-20 21:52:51 Couldn't fetch records
Offline weather34
« Reply #4 on: March 21, 2019, 02:55:35 AM »
good morning sorry for not getting back earlier , looking at your site your connection to the dbase is failing ..so therefore any scripts in stationcron.php wont run . quick dirty fix is goto setup screen and choose chartswu option until you can resolve connection to database. a guide i did sometime ago might help with mysql https://weather34.com/homeweatherstation/guides/setupmeteobridge.html
a basic guide https://weather34.com/homeweatherstation/guides/setup.html
also look for user prestwick (chuck) he is on your side of the pond he uses purple air with template for a long time I dont own a purple air so Im not the expert and not much help I use just relied on others input when it comes to purple air. ..brian
    • Texas Weather
« Reply #5 on: March 21, 2019, 01:09:07 PM »
I think I have sorted out... Thanks for the pointers Brian!
