Author Topic: Weather Computer Died need help  (Read 2616 times)
Offline mkutche
    • GosportWx.com
Re: Weather Computer Died need help
« Reply #25 on: December 21, 2018, 06:32:53 PM »
Twitter may have changed how apps are authorized since Cumulus 1.9.4 was done 4 years ago (14-Nov-2014).  They now rely on OAuth to do the authentication and don't allow simple REST POST with credentials anymore.  My TweetWX scripts (using OAuth) seem to still be working, so you might consider switching to using website-based conditions/forecast Tweets as I do.
ok i will look into it thanks :)
Mike K.
Davis Vantage Vue 6250 - CumulusMX (3.21.1-b3205)
Gosport, Indiana
Gosportwx.com twitter.com/GosportINWX
Offline ConligWX
  • #conligwx
    • conligwx.org
« Reply #26 on: December 22, 2018, 12:47:40 AM »
If you upload to Weathercloud, they allow uploading to Twitter from your account.
Sent from my ONEPLUS A6003 using Tapatalk
Regards Simon
Offline Maumelle Weather
    • Maumelle Weather
« Reply #27 on: December 22, 2018, 08:24:39 AM »
Hi Mike,
I just started following you on Twitter, and I use the TweetWX scripts Ken is talking about. The scripts update my stations' conditions every 10-15 minutes, and they update the NWS forecast every hour. I use a CRON to update the station information.
GR2AE, GR3, Cumulus
Offline mkutche
    • GosportWx.com
« Reply #28 on: December 22, 2018, 09:31:05 AM »
Hi Mike,
im getting this 12:00am 0°F (H 0/L 0)  Hum:% Wind:Calm Baro: 0.00in Rain: 0.00in http://goo.gl/N5AHJe  #INwx #AGwx when it updates to twitter. Thanks for the follow :)
Also says i need weather display which i dont have :( anyway around that?
« Last Edit: December 22, 2018, 09:38:07 AM by mkutche »
Mike K.
Gosport, Indiana
    • Maumelle Weather
« Reply #29 on: December 22, 2018, 09:43:48 AM »
Hi Mike,
You do NOT need Weather Display. I am running CumulusMX.
GR2AE, GR3, Cumulus
Offline mkutche
    • GosportWx.com
« Reply #30 on: December 22, 2018, 09:45:52 AM »
Hi Mike,
arent u using Ken's TweetWX Conditions.php? do u have the settings for it to run with Cumulus 1.94?
« Last Edit: December 22, 2018, 09:49:02 AM by mkutche »
Mike K.
Gosport, Indiana
    • Maumelle Weather
« Reply #31 on: December 22, 2018, 09:50:58 AM »
Hi Mike,
arent u using Ken's TweetWX Conditions.php? do u have the settings for it to run with Cumulus?
I am using the TweetWX scripts. The settings for it to use Cumulus are the same as the ones used for the Base template. One thing to check is the path for the $wxdir settings in the TweetWX-conditions.php (e.g. - /home/username/public_html/) to get it to work correctly.
GR2AE, GR3, Cumulus
Offline mkutche
    • GosportWx.com
« Reply #32 on: December 22, 2018, 09:54:30 AM »
with Godaddy they just use / for the directory.. idk what else im doing wrong. TweetWX-forecast.php works fine.. cant get conditions to work for some reason
Mike K.
Gosport, Indiana
Offline mkutche
    • GosportWx.com
« Reply #33 on: December 22, 2018, 09:58:20 AM »
include_once($wxdir . 'CUTags.php');
$uomTemp = '°F';
$uomWind = 'mph';
$uomBaro = 'in';
$uomRain = 'in';
Mike K.
Gosport, Indiana
    • Maumelle Weather
« Reply #34 on: December 22, 2018, 10:01:05 AM »
I had tried that as well, but it did not work for me, either. Once I added the hard path to it, it worked.
GR2AE, GR3, Cumulus
Offline mkutche
    • GosportWx.com
« Reply #35 on: December 22, 2018, 10:02:05 AM »
ok lets see if that works.
Mike K.
Gosport, Indiana
Offline mkutche
    • GosportWx.com
« Reply #36 on: December 22, 2018, 10:06:03 AM »
still shows 12:00am 0�F (H 0/L 0) Hum:% Wind:Calm Baro: 0.00in Rain: 0.00in goo.gl/N5AHJe #INwx #AGwx
len=90
Mike K.
Gosport, Indiana
    • Maumelle Weather
« Reply #37 on: December 22, 2018, 10:08:40 AM »
$uomTemp = '°F';
$uomWind = 'mph';
$uomBaro = 'in';
$uomRain = 'in';
On your CUTags.php. It "should" be CUtags.php. This could be the issue.
Edit: Unless you re-named it.
GR2AE, GR3, Cumulus
Offline mkutche
    • GosportWx.com
« Reply #38 on: December 22, 2018, 10:12:31 AM »
$uomTemp = '°F';
$uomWind = 'mph';
$uomBaro = 'in';
$uomRain = 'in';
renamed it.. should this be changed from advforecast.php to CUTags.php??
$wxdir = '../';  // path to the advforecast2.php
Mike K.
Gosport, Indiana
    • Maumelle Weather
« Reply #39 on: December 22, 2018, 10:14:05 AM »
$uomTemp = '°F';
$uomWind = 'mph';
$uomBaro = 'in';
$uomRain = 'in';
This is what mine look like:
include_once($wxdir . 'CUtags.php');
$uomTemp = '°F';
$uomWind = 'mph';
$uomBaro = 'in';
$uomRain = 'in';
Also my settings are:
// --------------- settings ----------------------
include ("Settings.php");
$tweetWXdir = './';
$wxdir = '/home/sacrey/www/www/';  // path to the advforecast2.php
$tweetTags = '#ARwx';  // customize for your Twitter tags and/or website url (shortened)
// ----------- end settings ----------------------
GR2AE, GR3, Cumulus
Offline mkutche
    • GosportWx.com
« Reply #40 on: December 22, 2018, 11:02:46 AM »
so i upgraded to cumulusMX and i get CUtags.php to upload but its saying Cumulus Weather Data not updated what gives?
Mike K.
Gosport, Indiana
    • Maumelle Weather
« Reply #41 on: December 22, 2018, 11:10:01 AM »
Your site is still showing Cumulus 1.9.4 as being the main software. In CumulusMX, got through all the settings carefully, then add the additional files under Settings, Extra Web Settings just like you do in Cumulus1.
GR2AE, GR3, Cumulus
Offline mkutche
    • GosportWx.com
« Reply #42 on: December 22, 2018, 11:19:31 AM »
did idk whats goin on.
Mike K.
Gosport, Indiana
    • Maumelle Weather
« Reply #43 on: December 22, 2018, 11:25:28 AM »
I am guessing that Cumulus 1.9.4 is not running, and CumulusMX is running?
GR2AE, GR3, Cumulus
Offline mkutche
    • GosportWx.com
« Reply #44 on: December 22, 2018, 11:28:19 AM »
yep usually when i upload CUtags.php both Cumulus FTP & Cumulus weather data both say current and they dont only Cumulus FTP. Never had this issue before.
Mike K.
Gosport, Indiana
    • Maumelle Weather
« Reply #45 on: December 22, 2018, 11:35:55 AM »
That is very strange......I have not ever seen that issue before, either.
GR2AE, GR3, Cumulus
Offline Intheswamp
    • Beeweather
« Reply #46 on: December 22, 2018, 11:47:50 AM »
I've had those ...sunmoon.php warnings for several days now.  Hopefully someone will clue us in on what's going on, I just haven't pursued figuring them out yet.
https://www.wxforum.net/index.php?topic=35729.new#new
https://cumulus.hosiene.co.uk/viewtopic.php?f=25&t=17177
looks like USNO has become flakey again... they do this from time to time.
FWIW...the errors have disappeared this morning.
Davis VP2, v3.12
Cumulus v1.9.4  Build 1079
www.beeweather.com
www.beausandbonnets.com
Offline mkutche
    • GosportWx.com
« Reply #47 on: December 22, 2018, 12:32:44 PM »
ok that headache is gone.. lol everything is uploading like it should until i get a chance to add 3 more files to cumulus mx but anyway i still cant get the conditions to work right.
well it was working right now its reading 0.. lol omg
« Last Edit: December 22, 2018, 12:34:35 PM by mkutche »
Mike K.
Gosport, Indiana
Offline PaulMy
« Reply #48 on: December 22, 2018, 12:44:20 PM »
@mkutche
Looks like you've got the uploads working...
In your status the NOAA reports are not shown as current and likely need to change from /reports to /Reports
http://gosportwx.com/Reports/NOAAYR2018.txt
http://gosportwx.com/Reports/NOAAMO1218.txt
By the way your Cumulus (3.0.0 - b3044) in your header has the old Sandaysoft link and gives a 404 not found error.  If you can be patient a new b3045, that includes a fix, may be posted soon...
Enjoy,
Offline mkutche
    • GosportWx.com
« Reply #49 on: December 22, 2018, 12:59:25 PM »
@mkutche
Enjoy,
had my d drive crash my reports will say that until midnight night. i'll update when the new b3045 is out.. im still trying to figure out why TweetWX-conditions.php isnt working..
Mike K.
Gosport, Indiana
