Author Topic: WXStatus & GRlevel3  (Read 870 times)
Offline mkutche
    • GosportWx.com
WXStatus & GRlevel3
« on: December 16, 2018, 04:38:26 PM »
So for now I have GRlevel3 publishing (uploading) to another server IE. http://www.mikeswxblog.com/GR3 my question is how do i implement this in this code so it actually shows it is being updated?
# start of custom checks (put your custom checks below)
        $tDir = './GR3/';
if(file_exists($tDir.'kind_br1_0.jpg')) {
           do_check(langtransstr("GRlevel3 Radar FTP"),$tDir.'kind_br1_0.jpg',10*60+15,'file');
                if(file_exists("radar-status.php")) { // add radar status check if available
   echo " <tr>\n";
   echo "   <td colspan=\"4\">\n";
   include_once("radar-status.php");
   echo "</td>\n";
   echo " </tr>\n";
        $tDir = './';
if(file_exists($tDir.'forecast-summary.txt')) {
           do_check(langtransstr("Forecast Summary"),$tDir.'forecast-summary.txt',10*60+15,'file');
# end of custom checks
« Last Edit: December 16, 2018, 04:52:54 PM by mkutche »
Mike K.
Davis Vantage Vue 6250 - CumulusMX (3.21.1-b3205)
Gosport, Indiana
Gosportwx.com twitter.com/GosportINWX
Online saratogaWX
Re: WXStatus & GRlevel3
« Reply #1 on: December 16, 2018, 10:45:21 PM »
Since http://www.gosportwx.com/ and http://www.mikeswxblog.com/GR3 likely have different document roots in the filesystem, you may not be able to use relative addressing to say where (exactly) the GR3 directory is from one site to the other.
You need to know the absolute paths in the filesystem for each site to determine if relative addressing from the gosportwx site to the mikeswxblog site is possible.
Offline R_o_B
« Reply #2 on: December 17, 2018, 12:25:36 PM »
Ken, would using the 'realpath' PHP function not give him the canonicalized absolute pathname?
Remember not too long ago when I had to deal with the location of the True Type fonts and my solution was to, indeed, use the 'realpath' function...
R_o_B
eMail: weather@herray.net
Online saratogaWX
« Reply #3 on: December 17, 2018, 12:32:41 PM »
I think he still has to understand the absolute paths to the respective directories on both sites in order to craft a relative address on the gosport site in wxstatus.php to the GR3 directory in the mikeswxblog site (assuming that BOTH are under his main hosting directory).
the realpath() function won't help unless you know the exactly what relative file addressing needs to be used -- it would then flesh out the absolute path for you, but you have to start with a good relative file path in the first place.
