Author Topic: Add Advisory Bar to Forecast Webpage of Saratoga Template  (Read 362 times)
Offline Buford T. Justice
« on: November 25, 2018, 07:35:44 PM »
I am trying to figure out with the Saratoga Weather templates how to add the weather advisory bar that is on index.php to the forecast webpage.
I figured I would put this code somewhere on wxforecast.php
<?php // insert desired warning box at top of page
if(isset($SITE['NWSalertsCodes']) and count($SITE['NWSalertsCodes']) > 0) {
// Add nws-alerts alert box cache file
include_once("nws-alerts-config.php");
include($cacheFileDir.$aboxFileName);
// Insert nws-alerts alert box
echo $alertBox;
<script type="text/javascript" src="nws-alertmap.js"></script>
Whenever I add this, it breaks the forecast until I remove it.
Re: Add Advisory Bar to Forecast Webpage of Saratoga Template
« Reply #1 on: November 25, 2018, 11:12:51 PM »
You're just missing the closing } on the if statement.
This code works fine
<div id="main-copy">
echo $alertBox;
         <?php
 $doIncludeNWS true// handle advforecast2.php include
 $doIncludeWU  true// handle WU-forecast include also
 $doInclude    = true// handle ec-forecast and WXSIM include also
 $doPrint    = true//  ec-forecast.php setting
 include_once($SITE['fcstscript']); ?>
</div><!-- end main-copy -->
« Reply #2 on: November 26, 2018, 12:57:03 AM »
Thanks saratogaWX!  If anyone else is wanting to do this, the file the above code replaces is in "wxforecast.php" at Line 72.  That may vary with new releases of the script.
« Last Edit: November 27, 2018, 09:26:05 PM by Buford T. Justice »
