Author Topic: Davis Vantage Pro2 6152CEU + 6510 to SCADA  (Read 1086 times)
Offline p001p
« on: November 13, 2018, 04:03:36 AM »
Hello!
Don't know Eng very well so...
1. We have Davis Vantage Pro2 6152CEU + 6510
2. We need to show data inside our SCADA
What's wrong?
1. Do we have easy way (without JSON, AJAX, XML, etc.... ) to share the data from Davis equipment to .... MSQL for example? From MSQL we take the data for SCADA.
2. We can't use wireless networks. No intenet, no GSM, no GPS, have no GLONASS, nothing except cable / wire.
Offline johnd
Re: Davis Vantage Pro2 6152CEU + 6510 to SCADA
« Reply #1 on: November 13, 2018, 04:25:42 AM »
Does your SCADA/BMS speak Modbus? If so then there are solutions.
Cambridge UK
Offline p001p
« Reply #2 on: November 13, 2018, 04:36:30 AM »
Yes! We have a lot of OPC servers so we can take all of them, TCP? RTU? ASCII?
Offline johnd
« Reply #3 on: November 13, 2018, 04:48:46 AM »
OK then you need the serial version of the Weatherlink logger (6510SER) - USB will not work in this configuration. And then an Ocean Controls KTA282 Modbus card. We sell them if your're interested. https://www.weatherstations.co.uk/modbus.htm
« Last Edit: November 13, 2018, 04:51:30 AM by johnd »
Cambridge UK
Offline p001p
« Reply #4 on: November 13, 2018, 04:59:41 AM »
p8 in ur manual is possible adress registres?
Offline p001p
« Reply #5 on: November 13, 2018, 05:01:11 AM »
wow, it's impossible to buy it in Russia (Ocean Controls....)
Is it real to use smthing else?
« Reply #6 on: November 13, 2018, 10:45:55 AM »
There are WFI based logger modules that will output to an SQL database (not  mSQL, but that should  not be too much of an issue to attach your DB)  Look at Smartbedded (out of Germany) "Meteobridge Nano".
Offline Kit
« Reply #7 on: November 03, 2020, 03:14:24 AM »
If still relevant.  There is a free solution to this problem using the modbus Universal opc server program from Insat and the written script.
Offline Kit
« Reply #8 on: November 03, 2020, 03:33:09 AM »
Пример
