Author Topic: Issue with the icons in the Saratoga Weather NWS Forecast Script  (Read 321 times)
Offline Gonzo1982
Hello,
I'm having an issue with the icons in the saratoga weather nws forecast script.  If I call the script from inside my wordpress website, the images don't show, https://coffeesevereweather.com/current-forecast/.  But if I call the script by going straight to it, https://coffeesevereweather.com/advforecast2.php, it works fine.  Any ideas?
Online saratogaWX
Re: Issue with the icons in the Saratoga Weather NWS Forecast Script
« Reply #1 on: April 16, 2018, 11:04:27 AM »
It's due to the WordPress site and the scripts aren't really designed to handle how WordPress tweaks about with the URL:filesystem path mappings.
The easiest way to get it to work in a WP page is to use an <iframe> to reference the content where you know it works (your document root).
Something like
<iframe src="https://coffeesevereweather.com/advforecast2.php" width="620" height="1024" scrolling="no">
</iframe>
on your /current-forecast/ WP page.  You may have to adjust the height to get it all to fit without scrollbars.
The advforecast2.php script could likely be used on your main index.php setup, but not in a sub-page due to the relative directory addressing.
Hope this helps...
Offline Gonzo1982
« Reply #2 on: April 16, 2018, 11:10:17 AM »
Thanks, That gets me going for now.  I'll keep messing with calling the script.  Maybe I can get it working.  Thanks for your scripts btw.  Using the GR3 radar and now the forecast, both are very useful.
Online saratogaWX
« Reply #3 on: April 16, 2018, 11:19:07 AM »
Keep in mind that for advforecast2.php to work correctly, the URL-path and Filesystem-path need to match.  That is:
advforecast2.php
DualImage.php
./forecast/images/*
./forecast/icon-templates/*
need to have that filesystem and URL-path setup to operate properly.  By 'match' I mean that
http://your.website.com/  maps to /home/somepath/httpdocs
http://your.website.com/forecast/images/skc.jpg  maps to /home/somepath/httpdocs/forecast/images/skc.jpg
etc.  WordPress does funny internal mapping so the URL-path and filesystem path for the real file don't always match and that breaks the script.
Oh, and don't change the internal addressing in advforecast2.php from relative filesystem addressing (./forecast/images) to URL addressing (https://...) -- it will break the script in other ways.
« Last Edit: April 16, 2018, 11:21:10 AM by saratogaWX »
Offline Gonzo1982
« Reply #4 on: April 16, 2018, 11:24:02 AM »
Alright, I feel like I should be able to get this fixed somehow.  On your GR3 script, it's pulling the radar images from a separate folder, like /gr3/khtx_br1_0.jpg and that's loading fine in WordPress, https://coffeesevereweather.com/real-time-radar/
Online saratogaWX
« Reply #5 on: April 16, 2018, 11:45:15 AM »
The GRlevel3 radar script does some funny stuff (of which I'm not proud) to try and suss out the URL address of /GR3 with the filesystem address of the same.  It is the only script of mine that does that, and I don't recommend trying to clone that method into advforecast2.php.
A simpler approach (if you have SSH access to your website) is to create a symlink inside the /current-forecast/ directory to where the 'real' forecast directory is like
cd httpdocs/current-forecast
ln -s ../forecast forecast
ln -s ../advforecast2.php advforecast2.php
ln -s ../DualImage.php DualImage.php
Then have the page do the equivalent (in WordPress) of
include("advforecast2.php"); and the page should display completely and be happy with the subdirectory placement of the WP page.
Offline Gonzo1982
« Reply #6 on: April 17, 2018, 10:33:57 AM »
I was able to make the iframe work by messing with the css to change the colors to match my theme.  One question though, is there a way to remove all of the dead white space to the right or center the content to the page?
