Author Topic: menubar.php error - foreach()  (Read 1171 times)
Offline W3DRM
    • Emmett Weather
« on: January 13, 2018, 02:19:41 PM »
Just noticed that I am getting an error that shows up in the menubar.php code. It seems to be saying there is something wrong with the foreach() statement. I've attached a screen capture of what the menu error looks like. No changes to the menubar.php file have been in many months.
I am running the latest versions of everything. All routines are current, based on the check-fetch-times.php?show=versions code. All Win10 updates are current too. Am running PHP v7.1.13. Don't know when this actually started as I didn't notice it until this morning. I see the same error on multiple computers and various browsers.
--- RIPE Atlas Probe - 32849
Re: menubar.php error - foreach()
« Reply #1 on: January 13, 2018, 02:58:11 PM »
Hi Don,
Your nws-alerts.php is reporting
Warning: A non-numeric value encountered in /homepages/14/d239618093/htdocs/nws-alerts.php on line 127
Warning: Illegal string offset 'Greater Lake Tahoe Area (NV)' in /homepages/14/d239618093/htdocs/nws-alerts.php on line 219
Warning: Illegal string offset 'Greater Reno, Carson City, Minden' in /homepages/14/d239618093/htdocs/nws-alerts.php on line 219
Fatal error: Uncaught Error: [] operator not supported for strings in /homepages/14/d239618093/htdocs/nws-alerts.php:306 Stack trace: #0 {main} thrown in /homepages/14/d239618093/htdocs/nws-alerts.php on line 306
Your site is running PHP Version: 7.1.13 .
Looks like some more initialization changes need to be made to the nws-alerts.php V1.37 script.  Change
// set variables
$ad      = '';
$vCodes  = '';
$noAlrt  = '';
$cmyzc   = '';
$aBox    = '';
$box     = '';
$atData  = '';
$noData  = '';
$WA      = '1';
$logData = '';
$Status  = '';
$fltrd   = '^FF';
$ai      = array();
$bi      = array();
$noA     = array();
$codeID  = array();
$ano     = array();
$norss   = array();
$abData  = array();
$rssData = array();
$adnoBI  = array();
$uts = date("U");     // current unix time stamp
$timenow = date("D m-j-Y g:i a",$uts);
to
// set variables
$ad      = array();
$vCodes  = '';
$noAlrt  = array();
$cmyzc   = '';
$aBox    = '';
$box     = '';
$atData  = array();
$noData  = false;
$WA      = '1';
$logData = array();
$Status  = '';
$fltrd   = '^FF';
$ai      = array();
$bi      = array();
$noA     = array();
$codeID  = array();
$ano     = array();
$norss   = array();
$abData  = array();
$rssData = array();
$adnoBI  = array();
Curly was using null strings to initialize most variables.  PHP7 dislikes changing type (string) to (array) and so barfs at it.  The fix is to initialize the variables to the correct type.
Offline W3DRM
    • Emmett Weather
« Reply #2 on: January 13, 2018, 04:34:01 PM »
Aha, I just moved to PHP v7.1.13 about a week ago so that is probably what triggered the errors.
Thanks for the quick resolution! Will make the change a little later this afternoon. I'm sharpening my wife's kitchen knives at the moment and probably shouldn't stop...  ;)
Offline W3DRM
    • Emmett Weather
« Reply #3 on: January 13, 2018, 06:32:04 PM »
Okay, I updated the nws-alerts.php file but the issue remains. I've checked to make sure the new code did, in fact, get uploaded and it did. I've also refreshed the page too without any luck. Additionally, the CRON job is running.
Offline tmabell
    • Mishawaka Weather
« Reply #4 on: January 15, 2018, 02:23:06 PM »
I don't know if this is relevant but I am using PHP 7.2 and I've not experienced any errors.  For what it's worth this is my section that Ken referenced:
// set variables
$ad      = '';
$vCodes  = '';
$noAlrt  = '';
$cmyzc   = '';
$aBox    = '';
$box     = '';
$atData  = '';
$noData  = '';
$WA      = '1';
$logData = array();
$Status  = '';
$fltrd   = '^FF';
$ad      = array();
$noAlrt  = array();
$ai      = array();
$bi      = array();
$noA     = array();
$codeID  = array();
$ano     = array();
$norss   = array();
$abData  = array();
$rssData = array();
$adnoBI  = array();
$atData  = array();
Offline W3DRM
    • Emmett Weather
« Reply #5 on: January 15, 2018, 07:07:37 PM »
Now I am baffled - the problem has gone away. I no longer see any errors in my menu. So, whatever it was, has disappeared, for the time being. Will keep a watch on it. Thanks for the help and feedback.
