Author Topic: Alternative Dashboard version 6.95 Released  (Read 70829 times)
Offline bucks County Weather
    • http://www.backyardweather.org
Re: Alternative Dashboard version 6.90 Released
« Reply #25 on: October 28, 2013, 07:46:26 PM »
My Length of Day Pie chart reverts back to the older style sun icon after about 20 minutes. Were there any settings in the ajax config I may have missed?
Chris
Offline BurnsvilleWeather
  • Burnsville, MN USA
  • Retired from Weather!
« Reply #26 on: October 28, 2013, 08:16:05 PM »
You aren't using the new version of ajaxwdwx3.js.  read the READ-ME-1ST.txt file in the archive and you will see how to modify your setup to use it.
Scott
« Last Edit: October 28, 2013, 09:04:00 PM by BurnsvilleWeather »
www.BurnsvilleWeatherLIVE.com (Formally Webster Weather LIVE)
Home of the Alternative Dashboard and Mobile Dashboard Scripts. Weather Display Scripts and Graphics
Davis VP2 with, UV, Solar, Leaf, Web Cam.
« Reply #27 on: October 28, 2013, 08:59:05 PM »
the newest version in the most recent release....correct...i'm using the ajaxwdwx3 but from the last release...
thanks....i'll fix it tomorrow .
Chris
« Reply #28 on: October 28, 2013, 09:06:38 PM »
I've updated the instructions with some images for the rain graphic setup and the fix for 24 hour format (from Alessandro) on the update clock.  Thanks for the suggestions and tips!
Scott
« Last Edit: October 28, 2013, 09:11:21 PM by BurnsvilleWeather »
« Reply #29 on: October 30, 2013, 10:03:38 PM »
Update:
It appears that you folks like your graphics to be near live so the rain graph not updating was not acceptable!  ](*,)  Thanks to Gerald W, we have a routine to update that graphic automatically too!  You can download the minor update now on my site (see message #1 for the link).  This update is only identified by it's date Version 6.90 - 30-OCT-2013
Scott
Offline i_fiorentino
  • Davis Vantage Vue, Boltek Stormtr., Mobotix M22-IT
    • Meteopistoia.it
« Reply #30 on: October 31, 2013, 02:45:22 AM »
Update:
Scott
Hi Scott, is it possible to know which code is changed?
Because i've made some modifications about italian translation.
In particular, i've change those words can not be translated because they have an "enpty" space before.
F.e.: " Illuminated".
In all these cases just put the " " before these words to fix the translation.
These changes must be done on the language-xx.txt file too. ;)
Regards,
Alessandro
« Last Edit: October 31, 2013, 12:40:00 PM by i_fiorentino »
Offline Torjan
    • regnskvett
« Reply #31 on: October 31, 2013, 11:34:46 AM »
There are a few things that do not work, it is the translation of the current conditions. When ajaxWDwx3 kicks in the text is in English.
I have the wrong value of the dew point in the last hour (see attachments). This is also ajaxWDwx3 thing.
Offline jonnyj771
    • Lightning Weather
« Reply #32 on: October 31, 2013, 05:44:06 PM »
Scott,
Everything is working ok for the most part. The only issue I am having is with the previous highs and records.
When you load the page http://lightningweather.com, You can see the correct highs/lows and records.
When the page completes loading and the numbers turn green, the records/yest. temps go completely haywire.
I live just south of you in Iowa. I don't think it was 113 here yesterday. Infact, I know it was raining rather profusely yesterday.. 8-)
I have gone through all of the settings in the ajax-dashboard.php (6 removed), ajaxdashboardconfig6.php and the ajaxWDwx3.js (removed the three in the name to keep my pages current).
Maybe with the new settings on the ajax-dashboard.php it's looking for the .js to have the 3 in it?!? Doubtful since everything else is fine. Wanted your input.
Facebook:
Lightning Weather
   www.facebook.com/lightningweather
                             /groups/lightningweather
Lightning Weather Quad Cities
                             /lightningwxqc
                             /groups/lightningWXQC
Weather Station Hardware: Davis Vantage Pro2 6152
Weather Station Software: WD - 10.37S Build XXX (Beta)
Page Template: MeteoTemplate v1x. (Current Active)
« Reply #33 on: October 31, 2013, 06:31:48 PM »
The problem is in the ajaxWDwx3.js, can you send me your copy (rename it to .txt) to my email (click the mail icon under my name to the left)
Scott
Scott,
Offline Jumpin Joe
    • Joe's Live Weather
« Reply #34 on: October 31, 2013, 06:33:38 PM »
Are you view it with an iPad or iPhone with iOS 7?
If so, try looking at it on windows device using IE, FF or Chrome. Should Look fine. It's a Apple issue, my site does the same thing.
I hope this helps,
Joe
Davis Pro 2 Plus Wireless D-FARS - Weather Link Serial 5.9.2
Weather Display Version10.37S Build 6
http://www.joesweather.info
Joe's Bloomsky
CWOP: EW2334  Blitzortung ID: 791
Offline CNYWeather
  • Yeah, I'm hugging my traffic light.
    • http://www.cnyweather.com
« Reply #35 on: October 31, 2013, 07:07:10 PM »
Installed 6.90
First of all THANK YOU Scott. I'm having 1 issue before I start putting a few mods on here.
Bottom of the dashboard, I have 5 columns tring to squish into 4. The headings are not in the correct position
TY
http://www.cnyweather.com/indextest.php
Tony
Offline jonnyj771
    • Lightning Weather
« Reply #36 on: October 31, 2013, 07:11:35 PM »
Scott
Scott,
Sent you a PM Scott
Facebook:
Lightning Weather
                             /lightningwxqc
« Reply #37 on: October 31, 2013, 07:15:32 PM »
Its looking fine to me on my browser but you aren't using the new ajaxWDwx3.js file!!  That might be part of the problem.
Scott
Installed 6.90
TY
Offline giantocr
« Reply #38 on: November 01, 2013, 04:55:01 AM »
Hi Scott,
There is a typo in the last AltAjaxDashboardConfig6.php on line 38.
There is $spc_img that should be $spc_image.
Cheers,
Piet
http://www.weerstation-sauwerd.nl
http://www.meteosauwerd.nl
« Reply #39 on: November 01, 2013, 09:57:25 PM »
Hi Scott,
Cheers,
Piet
Piet,
Make sure you are using the newest config and dashboard (dated 26-Oct-2013 or later).  The archive that is online now is correct for both.  It should be $spc_img for both!  There must have been one bad file in one of the previous archives.  Sorry about that!
Scott
    • Meteopistoia.it
« Reply #40 on: November 02, 2013, 11:09:43 AM »
Hi Scott,
i've tested new rain today image on dashboard but it doesn't work as it should.
Please, look the image below:
Rain today image shows 0.00 but it should shows 3.6mm.
What's wrong?
Regards,
Alessandro
Offline gwwilk
  • Southeast Lincoln Weather
« Reply #41 on: November 02, 2013, 11:15:16 AM »
Hi Scott,
What's wrong?
Regards,
Alessandro
I had to play with the file create, the file upload, the save buttons, and the OK buttons before I hit upon the magic hidden combination that unlocked the update/upload of this graphic #7.  WD isn't updating it, isn't uploading it, or both.  Sorry I can't offer more concrete assistance with this arcane setup. :-(
Regards, Jerry Wilkins
gwwilk@inebraska.com
Offline jonnyj771
    • Lightning Weather
Re: Re: Re: Alternative Dashboard version 6.90 Released
« Reply #42 on: November 02, 2013, 11:36:57 AM »
Hi Scott,
What's wrong?
Regards,
Alessandro
You should notice it when you get a good steady rain. That shows the rate of rainfall/hour.  I had it going the last couple of days when I had a rain event. I'll be looking at another rain event on Tuesday and Wednesday.
Facebook:
Lightning Weather
                             /lightningwxqc
Offline gwwilk
« Reply #43 on: November 02, 2013, 11:46:29 AM »
'Today' (Oggi) rain of 3.60mm should show on the graph, but it isn't.  That's the problem.
« Last Edit: November 02, 2013, 11:48:37 AM by gwwilk »
    • Meteopistoia.it
« Reply #44 on: November 02, 2013, 11:59:28 AM »
Yes, quite so ;)
    • Meteopistoia.it
« Reply #45 on: November 02, 2013, 12:20:37 PM »
Now, it's raining outside but the image remains static :(
http://www.meteocarmignano.it/index.php
Offline ed2kayak
  • Ed
    • Cumberland Valley Weather
« Reply #46 on: November 02, 2013, 12:26:40 PM »
Is the raintoday.gif being created in your \wdisplay\webfiles directory at the time interval you selected?
I could get WD to reliably create it, but not upload it.
Ed
Offline gwwilk
« Reply #47 on: November 02, 2013, 12:29:50 PM »
It's all in the mysterious WD settings for graphic #7, Alessandro.  Keep playing with it.  Also be sure you're pointing at the correct graphic in AltDashboardConfig6.php.  That can also be a problem.  Check the file time of the raintoday.gif on your site with something like FileZilla.  If the file time is up to date but the graphic is still stale, then WD isn't updating the graphic but it's still uploading it.
Offline jgillett
  • unnamed weather station, Boltek, Win7 Pro, ToA
    • TiggrWeather Phoenix
« Reply #48 on: November 02, 2013, 12:30:11 PM »
Ed,
Like Jerry, it also took me some fiddling around in WD to finally get it to hold my settings and upload the data. Can't give you any specific steps - pretty much just trying over and over until it worked.
W7JKG
BUY FROM AMAZON  HERE... Thank You! :-)
    • Meteopistoia.it
« Reply #49 on: November 02, 2013, 12:37:47 PM »
This is the file on my root: http://www.meteocarmignano.it/raintoday.gif
This is my wd configuration:
Is it correct?
Regards,
Alessandro
