Author Topic: PC Project  (Read 53162 times)
Offline Lefty
Re: PC Project
« Reply #50 on: September 21, 2012, 09:43:30 AM »
Mmmmm.... workstation p0rn !
Here's the thing with the imbedded graphics vs. peripheral graphics cards: With imbedded graphics, your main processor has to do most of the heavy lifting to process what you see on the screen in addition to the other processing requests from the system. Does it slow down the processing ? Probably, but you most likely won't realize it until you start doing some heavy crunching that taxes your i5. Video\photo rendering could do that, but I can't say (my PC is for work).
Personally, I like to have my PC's processor dedicated to the system requests, so bought a mid-range video card (ATI 5770) to do the dedicated video.
-Steve- Peoria, AZ
Acu-rite 01515. That's it. No web page, no links, just me and my console.
Offline cospringswx
    • Colorado Springs Weather
Re: PC Project
« Reply #51 on: September 21, 2012, 10:16:52 AM »
The embedded graphics works good for what I do for now. BTW is that ATI card good?
Ryan
Colorado Springs, CO
www.cospringsweather.com
Davis Vantage Vue
Weather Display Software
Amcrest HD IP Camera
Offline cospringswx
Re: PC Project
« Reply #52 on: September 21, 2012, 10:25:37 AM »
My WEI is as follows...
Processor: 7.5
Memory: 7.8
Graphics:  5.1
Gaming Graphics: 6.4
Primary HDD:  7.9
« Last Edit: September 25, 2012, 07:43:13 PM by hayskswx »
Ryan
Davis Vantage Vue
Offline Lefty
Re: PC Project
« Reply #53 on: September 21, 2012, 10:56:10 AM »
My ATI card was considered mid-grade when I bought it ~2 years ago. If I had to do it all over again, I probably would pony up the extra $$ for a higher-end card. Even on a PC used primarily for crunching numbers, writing docs, and sending\receiving email, I find there are gliches in my display that are likely caused by limitations of the graphics card. Note, however, that I run dual displays (once you go dual, you will never go back !).
BTW, it's really a toss-up on the graphics processors when you are talking ATI vs. Nvidia. They both make good video, it's just that when I bought my card, there really weren't any decent mid-range Nvidia cards on the market.
-Steve- Peoria, AZ
Offline CNYWeather
    • CNYWeather
Re: PC Project
« Reply #54 on: September 21, 2012, 12:43:12 PM »
Yours looks so clean, which reminded me to open mine and get the dogs and cat hair out of them.
Lol. Take a picture of your PC.
I'd be embarrassed. Got 4 dogs and 2 cats running around lol
Tony
Offline cospringswx
Re: PC Project
« Reply #55 on: September 21, 2012, 02:48:50 PM »
 :lol: ok
Ryan
Davis Vantage Vue
Offline C5250
    • Local weather
Re: PC Project
« Reply #56 on: September 21, 2012, 09:09:10 PM »
If the fans concern you, you could always go H2O.  :lol: I see they have cooler blocks for vid cards nowadays.
I've long considered H2O, but that introduces other issues.
For hayskswx (or any else interested, my computer p0rn:
Workstation
Server
Nothing particularly fancy, but that's because my bias is reliability.
Precious little in your life is yours by right and won without a fight.
Offline cospringswx
Re: PC Project
« Reply #57 on: September 22, 2012, 11:08:44 AM »
Workstation
Server
Nice job with the wiring. Well I broke down and ordered the Gigabyte 430 GPU for $69 off newegg. It will suit my needs just fine and cheap!
Ryan
Davis Vantage Vue
Offline Cienega32
    • East Mesa Weather
Re: PC Project
« Reply #58 on: September 22, 2012, 04:33:14 PM »
Workstation
Server
I need a googley-eyed drooling emoticon!
Pat ~ Davis VP2 6153-Weatherlink-Weather Display-StartWatch-VirtualVP-Win7 Pro-64bit
Offline Cienega32
    • East Mesa Weather
Re: PC Project
« Reply #59 on: September 22, 2012, 04:35:14 PM »
Maybe more positive case pressure?
Offline C5250
    • Local weather
Re: PC Project
« Reply #60 on: September 22, 2012, 05:08:55 PM »
SATA makes that pretty easy, it was a disaster back when everything was IDE and SCSI and I had to use a slew of power Y's.
I think you'll be happy with the Gigabyte, it'll make it much less likely that you'll run into a program that can't be run.
Offline cospringswx
Re: PC Project
« Reply #61 on: September 22, 2012, 06:30:54 PM »
Do I have to turn onboard graphics off before I install the GPU or will it recognize it?
Ryan
Davis Vantage Vue
Offline gwwilk
  • Southeast Lincoln Weather
Re: PC Project
« Reply #62 on: September 22, 2012, 07:22:50 PM »
Maybe.
If you don't see the POST with no BIOS changes, reattach your monitor to the onboard GPU and then change the BIOS.
Regards, Jerry Wilkins
gwwilk@gmail.com
Offline cospringswx
Re: PC Project
« Reply #63 on: September 22, 2012, 08:54:33 PM »
You would think when I put the dvi cable from monitor in video card it would disable the onboard dvi port.
Ryan
Davis Vantage Vue
Offline C5250
    • Local weather
Re: PC Project
« Reply #64 on: September 22, 2012, 09:51:43 PM »
Nope. Actually, you can use the on board for a second monitor.
Offline C5250
    • Local weather
Re: PC Project
« Reply #65 on: September 23, 2012, 09:42:08 PM »
It depends on what options the BIOS offers. In some cases you can set the default graphics adapter. If there is not such an option, then you may have to disable the onboard graphics to see the POST process. If there is, but you are certain you'll never want to use the onboard graphics, then you may want to disable it.
Offline Cienega32
    • East Mesa Weather
Re: PC Project
« Reply #66 on: September 24, 2012, 01:12:56 AM »
I think the 'Auto' that the Gigabyte board defaults to should handle it either way. My UD5H defaults to auto - don't know if yours does.
Offline Lefty
Re: PC Project
« Reply #67 on: September 24, 2012, 09:42:26 AM »
So don't go into BIOS and disable? Just connect DVI to video card and I'm good to go?
Correct. If I'm not mistaken, your video card will probably be a PCI-E card. You can go into your BIOS now to see whether the PCI-E slot(s) are enabled, but I'm willing to bet that they are (i.e. set to Auto as Pat mentioned). Just plug in your card, move the DVI cable to it, and power on. You'll initially get just the basic VGA screen until Windows installs the correct drivers (or you install them),  but you are probably familiar with that process.
Now comes the fun part: if you have another monitor and cable, you can do as C5250 mentions and connect them up to the on-board video interface. Nothing beats having dual monitors. If not, then you *could* go into the BIOS and disable the on-board video to keep the CPU from crunching any instructions that may be destined for that interface. Knowing all the software and Windows, even if nothing is connected to those interfaces I'd be willing to bet that instructions processed by the CPU and sent to them. But that's just what my anal-retentive, geek-ness, would do...  :oops:
-Steve- Peoria, AZ
Offline cospringswx
Re: PC Project
« Reply #68 on: September 24, 2012, 05:33:59 PM »
The onboard graphics in the BIOS is set to auto so I should be ok?
Ryan
Davis Vantage Vue
Offline C5250
    • Local weather
Re: PC Project
« Reply #69 on: September 24, 2012, 07:57:36 PM »
Probably. Worst case, install the card, connect the display and see if anything appears. If not you have to go in to the BIOS.
This is what the MB manual for my C2SBC-Q (Phoenix BIOS) says:
Default Primary Video Adapter
This feature allows the user to select the video device used by the BIOS during
POST.  If  set  to  Auto,  PEG,  PCI,  and  IGD  (Internal  Graphics  Device)  devices
will be selected. If set to IGD (Internal Graphics Device), IGD and PCI devices
will be selected. If set to PEG, PEG and PCI devices will be selected. If set to
PCI, PCI, PEG and IGD devices will be selected.
What that means, when set to Auto, the BIOS search order is PCI-E, PCI and then the integrated. And which ever it finds first becomes the default adapter.
Offline Cienega32
    • East Mesa Weather
Re: PC Project
« Reply #70 on: September 25, 2012, 05:43:28 AM »
Same approach here as well. It's a horrible disease, isn't it?  :-P
Offline Cienega32
    • East Mesa Weather
Re: PC Project
« Reply #71 on: September 25, 2012, 07:28:51 AM »
I agree with both of you and for what I'm doing now its not needed so I will wait. I have also heard about the fans going out over time.  Could you two post pics of your PC's as I would be interested seeing it.
I put a few pics here:
http://www.wxforum.net/index.php?topic=16422.msg161337#msg161337
Offline cospringswx
Re: PC Project
« Reply #72 on: September 25, 2012, 01:26:44 PM »
Nice real nice! Looks like we have the same great taste.
Ryan
Davis Vantage Vue
Offline cospringswx
Re: PC Project
« Reply #73 on: September 25, 2012, 06:04:24 PM »
Moved Win 7 to SSD and now I got a 7.9 WEI score for primary hard disc. :grin:
Ryan
Davis Vantage Vue
Offline cospringswx
Re: PC Project
« Reply #74 on: September 25, 2012, 06:59:11 PM »
I have all the Win 7 files on my hdd and ssd. Can I delete off hdd and move user folder to hdd? It is set to boot off of ssd.
Ryan
Davis Vantage Vue
