Author Topic: PHP Moon Phase Script  (Read 29502 times)
Offline rubble
    • elginweather.com
« on: September 30, 2008, 12:51:39 PM »
Is anyone aware of a script that shows Moon Phase and Percent illumination?
I don't have Weather Display and I'm not looking for an image, I just want text.
Example:
Waxing Gibbous 28% Illumination.
    • Weatherelement Moline IL
Re: PHP Moon Phase Script
« Reply #1 on: September 30, 2008, 02:51:24 PM »
http://www.phpclasses.org/browse/package/1201.html
http://jivebay.com/2008/09/07/calculating-the-moon-phase/
Also, you say you don't have WD, if you have VWS, it has tags:
Moonrise   8:21am
Moonset   7:16pm
Moon Day  2    1%
With the Moon day or percent, you can script to choose the text description...
« Last Edit: September 30, 2008, 02:54:16 PM by SLOweather »
« Reply #2 on: September 30, 2008, 05:27:17 PM »
From the VWS Moon Day tag, you can use something like this WD specific function to decode what the phase should be based on the age and percent illumination .. adjust it to fit the VWS variable output for moon day/percent
// decode WD %moonage% tag and return a text description for the moon phase name
// "Moon age: 10 days,10 hours,41 minutes,80%"
function moonphase ($WDmoonage) {
  preg_match_all('|(\d+)|is',$WDmoonage,$matches);
//  print "<!-- matches=\n" . print_r($matches,true) . "-->\n";
  $mdays = $matches[1][0];
  $mhours = $matches[1][1];
  $mmins = $matches[1][2];
  $mpct  = $matches[1][3];
  $mdaysd = $mdays + ($mhours / 24) + ($mmins / 1440);
  // Definitions from http://www.answers.com/topic/lunar-phase
  //  * Dark Moon - Not visible
  //  * New Moon - Not visible, or traditionally, the first visible crescent of the Moon
  //  * Waxing Crescent Moon - Right 1-49% visible
  //  * First Quarter Moon - Right 50% visible
  //  * Waxing gibbous Moon - Right 51-99% visible
  //  * Full Moon - Fully visible
  //  * Waning gibbous Moon - Left 51-99% visible
  //  * Third Quarter Moon - Left 50% visible
  //  * Waning Crescent Moon - Left 1-49% visible
  if ($mdaysd <= 29.53/2) { // increasing illumination
    $ph = "Waxing";
$qtr = "First";
  } else { // decreasing illumination
    $ph = "Waning";
$qtr = "Last";
  if ($mpct < 1 ) { return("New Moon"); }
  if ($mpct <= 49) { return("$ph Crescent"); }
  if ($mpct < 51) { return("$qtr Quarter"); }
  if ($mpct < 99) { return("$ph Gibbous"); }
return("Full Moon");
Best regards,
Ken
Offline rubble
    • elginweather.com
« Reply #3 on: October 06, 2008, 01:15:41 PM »
I guess I should have posted more info.  I'm using VWS and my site runs from:
http://www.elginweather.com/vws/vwsfulldata.xml  and I don't upload any VWS image tags.
So I do have a <moon>7</moon> tag to work with.
How can this script be used?
<?php
$html
implode(''file('http://www.elginweather.com/vws/vwsfulldata.xml'));
preg_match('|<MOON>(.*)</MOON>|'$html$betweenspan);
$WDmoonage  $betweenspan[1];
function
$mdays $matches[1][0];
$mhours $matches[1][1];
$mmins $matches[1][2];
$mpct  $matches[1][3];
$mdaysd $mdays + ($mhours 24) + ($mmins 1440);
$ph "Waxing";
$qtr "First";
  } else {
$ph "Waning";
$qtr "Last";
  if (
$mpct ) { return("New Moon"); }
  if (
  if (
$mpct 51) { return("$qtr Quarter"); }
  if (
$mpct 99) { return("$ph Gibbous"); }
<p>moonday=<?php echo $WDmoonage?></p>
<p>ph=<?php echo $ph?></p>
<p>mpct=<?php echo $mpct?></p>
<p>qtr=<?php echo $qtr?></p>
« Reply #4 on: October 06, 2008, 03:16:54 PM »
If you only have the days in the cycle available, and not the percent illumination available, then you won't get an accurate descriptor for the moon-phase name, since that's based on percentage illumination, and only the waxing/waning is determined by first half/last half of the cycle.   Sorry...
Best regards,
Ken
Offline rubble
    • elginweather.com
« Reply #5 on: October 06, 2008, 05:30:11 PM »
The http://www.phpclasses.org/browse/package/1201.html  script blows!
I had that on my website and it needs constant attention.  Even the author said I shouldn't use it.
Offline Cristian
« Reply #6 on: April 10, 2009, 08:36:07 AM »
« Last Edit: April 13, 2017, 10:21:34 AM by Cristian »
Offline phingers
« Reply #7 on: March 21, 2011, 02:30:46 PM »
The hard coded variables in there, how often do they change?
Sun's apparent orbit, moons orbit.
Did the earthquake affect any of these variables?
Seems like a great script.
Anyway to tweak it to also show the rise and set times based on location?
