Author Topic: USA Extreme Script  (Read 912 times)
Offline SoMDWx
    • Southern Maryland Weather
USA Extreme Script
« on: November 30, 2017, 09:08:46 AM »
Hello All,
  I just installed the latest usaextremes.php script on my site. I see that you can get multiple sites for the high temperature of the day. Is there a way to just display one entry for each category rather then multiple ones?
Jim
Re: USA Extreme Script
« Reply #1 on: November 30, 2017, 12:34:16 PM »
The script runs through the listings, finds the maximum and minimum temperatures recorded, then passes through the list again looking for temperatures that match the maximum, also a pass for the minimum.  The script could be modified to stop at the first 'hit' in each category if you like, but it would be arbitrary as to which one (of the multiple ones) would be chosen.  I think that sorta defeats the intent of the script to find all the locations reporting the same max or min for a given day.  :?
Offline SoMDWx
« Reply #2 on: November 30, 2017, 12:42:58 PM »
Thanks! I think most people like to know what the high, low, and precip numbers for the US are, not necessarily all the locations but that's my own opinion...
I tried to modify that script in that section but it ended up giving me EVERY location i the list! lol
Jim
« Reply #3 on: November 30, 2017, 01:10:53 PM »
Ok.. try changing
// now pass through to see if any duplicate high, low, high precip exists and format the strings
foreach ($usaStations as $n => $vals) {
list($tHigh,$tLow,$tPrecip,$tPrecipEstim,$tData,$tState,$tStation) = explode("\t",$vals);
if($tHigh < -90 or $tLow < -90 ) { continue; }
if($tHigh == $usahighValue) {
$usahigh .= "<b>$tHigh$tUOM at $tStation, $tState</b>\n";
if($tLow == $usalowValue) {
$usalow .= "<b>$tLow$tUOM at $tStation, $tState</b>\n";
if($tPrecip == $usaprecipValue and $tPrecip > 0) {
$tPrecipFmt = sprintf("%01.2f",$tPrecip/100);
$usaprecip .= "<b>$tPrecipFmt$rUOM at $tStation, $tState</b>\n";
to
$gotLow = false;
$gotHigh = false;
$gotPrecip = false;
if($tHigh == $usahighValue and ! $gotHigh) {
$gotHigh = true;
if($tLow == $usalowValue and ! $gotLow) {
$gotLow = true;
if($tPrecip == $usaprecipValue and $tPrecip > 0 and ! $gotPrecip ) {
$gotPrecip = true;
and that should stop after the first one found for each of High, Low and Precip.
Offline SoMDWx
« Reply #4 on: November 30, 2017, 01:26:31 PM »
Thanks! That did the trick!   =D&gt;
JIm
« Reply #5 on: November 30, 2017, 01:31:16 PM »
Offline SoMDWx
« Reply #6 on: November 30, 2017, 02:13:47 PM »
Ken,
  Do you get my PM or email regarding my alert code using async vs. sync options within the XMLHTTP Get calls?
Jim
« Reply #7 on: November 30, 2017, 04:41:24 PM »
Hi Jim,
Yes, I did receive the email/PM at a time when the house was swarming with relatives so no time to really dig into it.  I'll look today.. sorry!
Offline SoMDWx
« Reply #8 on: November 30, 2017, 06:50:04 PM »
Understand... :lol:
