For reasons I dont care to get into because it will just drive me crazy again, I've had to swap out the laptop my Vantage Pro is on for the second time. This new unit is running Windows 10, and I cant run CP210X_USB_Serial_Converter. I am told "The code execution cannot proceed because CP210xManufacturing.dll was not found. Reinstalling the program may fix this problem"
Thats what I get when try to run the copy I downloaded from Davis. When I run the one that got installed w. Weatherlink located at c:\Weatherlink\Support\Drivers\, I get "Insufficient privileges. Contact, or log in as, the administrator to install this driver" I'm clearly logged in as an admin of the machine already
I hooked up the console to a USB port on the laptop, and it's feeding the data to Cumulus, but it wont go to wunderground. I'm sure I'm overlooking something simple here. In the Configuration menu in Cumulus, I went to internet, and chose Enabled under the Weather Underground section, and put in my station ID (KMAUXBRI10), and my password. No dice..... wunderground tells me "This PWS is not reporting" I've been waiting nearly 8 hrs
Anyone know whats up??
