Author Topic: Regional network mesonet-map updated V3.08  (Read 2118 times)
Online saratogaWX
« on: August 12, 2017, 09:08:48 PM »
One of our networks (CZWN) went HTTPS-only.
mesonet-map-common.php V3.08 was released to use curl for the access to the regional network's config/data files to produce the mesonet-map.
You can use mesonet-map-check-versions.php on your installation to see what file(s) may need update.
Download the full zip and instructions here or just the mesonet-map-common.php V3.08 - 12-Aug-2017 from here
Best regards,
Ken
Offline DW7240
    • The Vicarage Weather Feed
Re: Regional network mesonet-map updated V3.08
« Reply #1 on: August 12, 2017, 09:45:20 PM »
Thank you Ken as always for keeping us updated !!
Nick. dw7240.com.
Offline Jáchym
  • Meteotemplate Developer
    • Meteotemplate
« Reply #2 on: August 12, 2017, 09:57:34 PM »
Thank you very much Ken
Offline steven west
    • Potts Point Weather
« Reply #3 on: August 13, 2017, 01:55:13 AM »
Thanks Ken,
AUWN has been updated.
Steven
Potts Point - Sydney - Australia
WS2310 - 1Wire - Windows 10
Offline BeaumarisWX
    • BeaumarisWX
« Reply #4 on: February 13, 2018, 11:39:11 PM »
Seems the Mesonet Maps are not displaying, emailed Ken.
http://www.australiawx.net/forum/index.php?topic=61.msg123#msg123
Kind regards,
Tony Beaumaris, Tasmania (Australia)
CumulusMX GUI : https://beaumaris-weather.com/MXUI/
Saratoga Template : https://beaumaris-weather.com
Online saratogaWX
« Reply #5 on: February 14, 2018, 12:23:07 AM »
It appears to be a JavaScript error from the Google Maps API code.
In Firefox it says:
TypeError: g.b is undefined     js:120:483
trigger https://maps.google.com/maps/api/js:120:483
Tc https://maps.google.com/maps/api/js:50:406
_.J.prototype.bindTo https://maps.google.com/maps/api/js:123:328
_.Uv https://maps.google.com/maps-api-v3/api/js/32/1a/common.js:152:456
xz.prototype.f https://maps.google.com/maps-api-v3/api/js/32/1a/map.js:84:84
Ug/< https://maps.google.com/maps/api/js:92:4
Zd.prototype.za/</d[a]< https://maps.google.com/maps/api/js:125:2517
_.Ud/< https://maps.google.com/maps/api/js:60:195
Zd.prototype.za/< https://maps.google.com/maps/api/js:125:2627
$d https://maps.google.com/maps/api/js:62:209
Zd.prototype.za https://maps.google.com/maps/api/js:125:2369
<anonymous> self-hosted:952:17
<anonymous> https://maps.google.com/maps-api-v3/api/js/32/1a/map.js:1:1
in Google Chrome it says:
Uncaught TypeError: Cannot read property 'apply' of undefined
    at Object.trigger (js?key=AIzaSyA499ykaoUpr3YquZtJUtOcFFMgdjNKniU&language=en:120)
    at Tc (js?key=AIzaSyA499ykaoUpr3YquZtJUtOcFFMgdjNKniU&language=en:50)
    at Ug._.J.bindTo (js?key=AIzaSyA499ykaoUpr3YquZtJUtOcFFMgdjNKniU&language=en:123)
    at new _.Uv (common.js:152)
    at Object.xz.f (map.js:84)
    at Array.<anonymous> (js?key=AIzaSyA499ykaoUpr3YquZtJUtOcFFMgdjNKniU&language=en:92)
    at js?key=AIzaSyA499ykaoUpr3YquZtJUtOcFFMgdjNKniU&language=en:125
    at Object.<anonymous> (js?key=AIzaSyA499ykaoUpr3YquZtJUtOcFFMgdjNKniU&language=en:60)
    at js?key=AIzaSyA499ykaoUpr3YquZtJUtOcFFMgdjNKniU&language=en:60
in Microsoft Edge it says:
SCRIPT5007: SCRIPT5007: Unable to get property 'apply' of undefined or null reference js (120,483)
It looks like a Google Map API issue (it's their code that is causing the halt).. I'll continue to investigate.
Online saratogaWX
« Reply #6 on: February 14, 2018, 01:26:01 AM »
Looks like their V3.31 broke it.. you can do a quick fix by replacing (in mesonet-map.php or wxmesonetmap.php depending on which you use)
<script src="https://maps.google.com/maps/api/js?key=<?php echo $googleAPI?>&amp;language=<?php print $Lang?>" type="text/javascript"></script>
with
<script src="https://maps.google.com/maps/api/js?key=<?php echo $googleAPI?>&amp;language=<?php print $Lang?>&v=3.30" type="text/javascript"></script>
to force the older version API  to work.
I'll look at a 'real' fix for V3.31 Google API tomorrow...
Offline BeaumarisWX
    • BeaumarisWX
« Reply #7 on: February 14, 2018, 02:02:16 AM »
Thanks Ken,
greatly appreciated : Fix applied and works.
Kind regards,
Offline ConligWX
  • #conligwx
    • conligwx.org
« Reply #8 on: February 14, 2018, 05:10:59 AM »
Strange that Google themselves are showing 3.31 as experimental at time of writing:
https://developers.google.com/maps/documentation/javascript/versions
The developer's guide always describes the experimental version.
In addition, there is a separately maintained reference for each version:
Version 3.31 Reference (Experimental)
Version 3.30 Reference (Release)
Version 3.29 Reference (Frozen)
Versions 3.0 - 3.28 have been retired.
with
Regards Simon
« Reply #9 on: February 14, 2018, 08:27:46 AM »
Thanks much Ken. Fixed mine.
Offline jgillett
  • Boltek, Win7 Pro, ToA
    • TiggrWeather Phoenix
« Reply #10 on: February 14, 2018, 10:44:06 AM »
NE Phoenix, Arizona fixed.
Thank you, Ken.
W7JKG
Online saratogaWX
« Reply #11 on: February 14, 2018, 12:14:01 PM »
Further testing shows it works in GoogleMaps v=3.30 and v=3.31 but fails with the new(default) v=3.32
So you can use &v=3.30 or &v=3.31 and the map will work.  Using the default or &v=3.32 will fail.  Very strange.
I'm trying to dissect the mesonet-map.js code to see where the failure really lies.  Meanwhile, the quake-json map works fine with the default, as does the global-map scripts (which use much of the same code).
Offline 92merc
  • BismarckWeather.net
« Reply #12 on: February 14, 2018, 04:40:43 PM »
Thanks for the temp fix.  Only saw today mine wasn't working.  Already found a solution on the forum.
Offline steven west
« Reply #13 on: February 15, 2018, 02:59:04 AM »
Thanks Ken,
AUWN home page updated.
Steven
« Reply #14 on: February 15, 2018, 10:58:22 AM »
Thanks Ken, I've got it working again www.komokaweather.ca/wxmesonetmap.php
