Author Topic: 5n1 high temps fan IS running?  (Read 1899 times)
Offline daman
« on: June 26, 2017, 06:55:28 PM »
My 5n1 Pro is showing high temps everything is fine when it's cloudy but soon as the sun hits it temps start to clime the fan is running I confirmed it many times it is NOT roof mounted it's not getting any radiant heat. I hear the fan running but it sounds like it's running slower can these motors over time slow down? I think if it was running faster it would draw more air up through.
KMIBADAX38
AcuRite Iris/AcuRite Access
Offline DoctorKnow
Re: 5n1 high temps fan IS running?
« Reply #1 on: June 26, 2017, 07:22:35 PM »
I would recommend lubricating the fan motor, or replacing the motor. IT will never get any better, that I can guarantee if you just let it alone.
Offline daman
« Reply #2 on: June 26, 2017, 07:39:58 PM »
Yea I did all that I had it in for cleaning and inspection had it all apart lubed the fan shaft cleaned all dust etc, everything looks good, it just seems like the fan is not running fast enough. mine has the replaceable temps sensor do they ever go bad?
KMIBADAX38
Offline DoctorKnow
« Reply #3 on: June 26, 2017, 07:49:50 PM »
You said the temp & all is good until the sun comes out. That is a sign something is wrong with either the motor, wiring, or solar panels. Some have reported solar panel issues.
Offline daman
« Reply #4 on: June 26, 2017, 08:04:34 PM »
Does anyone know what these panels put out? I could try to get a reading.
I have the Pro with dual panels.
KMIBADAX38
Offline Garagedude
« Reply #5 on: June 27, 2017, 10:09:12 AM »
I have the same 5 in 1 that you do. If your 5 in 1 is in the sun its picking up radiant heat from the sun. I built a 6in thick insulated structure to inclose my temp sensor and have no more temp spikes like yours. Which means my temp sensor is located remotely from the 5 in 1 unit. If your interested in moving your sensor PM me and I'll be glad to share what I did.
Offline daman
« Reply #6 on: June 27, 2017, 08:33:07 PM »
Thanks you can PM them details sure. But I think I would like to try replacing the motor, anyone know a link to one that would work?
KMIBADAX38
Offline skysummit
    • StormCast
« Reply #7 on: July 01, 2017, 06:08:41 PM »
Here's my 5 in 1 with the fan running full speed compared to my tower sensor inside a radiation shield.  Thankfully I'm using the tower sensor as my primary temp/hum sensor when sending data.
Hardware:  Acurite Atlas with Lightning Detector
CoCoRaHs Station: LA-TG-11
NWS's Ponchatoula/Hammond Area's COOP Member
President | Director of Operations - StormCast
« Reply #8 on: July 01, 2017, 06:37:14 PM »
 :shock: That's terrible, especially with a fan. Is your tower sensor aspirated?
Offline skysummit
    • StormCast
« Reply #9 on: July 01, 2017, 07:16:01 PM »
Nope...just inside a radiation shield and is on the same post as my 5 in 1.
« Reply #10 on: July 01, 2017, 08:04:17 PM »
I see why so many complain about the 5 in 1 being in the sun. Wow.
Offline DoctorKnow
« Reply #11 on: July 01, 2017, 08:25:52 PM »
If the fan is running full speed, then the air sensor is malfunctioning. Try taking out the batteries, slide the A B C switch around a few times, return it to original position, and reinsert batteries. Report back if anything changes. I think the rush of air must do something to these air sensors, because mine did the same BS for a while with high temps like that. I didn't realize what fixed it until much later, and that was doing what I posted above.
Offline daman
« Reply #12 on: July 01, 2017, 09:53:13 PM »
Yeah something's going on if the fans full speed and you got temps like that.
Does anybody know what motor would be a direct replacement anybody got a link?
KMIBADAX38
Offline daman
« Reply #14 on: July 02, 2017, 01:08:14 PM »
Thanks Doc any idea what one would be better?
KMIBADAX38
Offline DoctorKnow
« Reply #15 on: July 02, 2017, 07:09:12 PM »
I would guess the first link, but I can't be sure.
