Author Topic: Weather station from Kerbach (FRANCE)  (Read 1647 times)
Offline gillesroszak
  • Qui trop écoute la météo, passe sa vie au bistrot.
    • meteokerbach
« on: May 17, 2017, 05:11:10 PM »
Hi
Here is the link to my pws  http://www.meteokerbach.fr
go and take a look.Some  pages will be added over time, be patient.
Regards
Offline Jáchym
  • Meteotemplate Developer
    • Meteotemplate
Re: Weather station from Kerbach (FRANCE)
« Reply #1 on: May 17, 2017, 05:15:06 PM »
not sure if it is just me, but the menu at the top loads fine, but then the page just hangs showing "Waiting for www.wunderground.com" and nothing happened even after reload and about 30s
    • meteokerbach
« Reply #2 on: May 17, 2017, 05:20:43 PM »
Try it again please it work fine from my PC
Offline Jáchym
    • Meteotemplate
« Reply #3 on: May 17, 2017, 05:29:23 PM »
OK now it works. Just be careful about copyright. You basically took the whole WU page and iframed it, not sure if this is ok. I know you can use the data if you send to WU, but you should use the XML feed for that, not the entire page. I am not 100% sure, but you need to check this.
    • meteokerbach
« Reply #4 on: May 17, 2017, 05:31:42 PM »
ok Jáchym i'll check that; but i'm not the only one to do that.
Offline Jáchym
    • Meteotemplate
« Reply #5 on: May 17, 2017, 06:22:37 PM »
Yes, thats true, I saw many websites with iframed radars etc., but unfortunately that doesnt make it any more ok does it...
You can use their API (by getting free API key) or the XML feeds, that is absolutely fine, but for the rest:
You may access, view and make copies of the Data in the Site for your personal, non-commercial use and will not publish or otherwise distribute the Data for any other purpose.
    • meteokerbach
« Reply #6 on: May 18, 2017, 07:16:01 AM »
Hi Jáchym
You're right that's why i want to use Weatherdashbord.I had thought to use Wunderground API but it's too complicated for me.
My level is not good enough to be able to succeed on my own.
Offline Jáchym
    • Meteotemplate
« Reply #7 on: May 18, 2017, 07:18:37 AM »
Sure, I think using a template is probably the ideal solution for you because everything you need will be done automatically without you having to know how to code :-)
    • meteokerbach
« Reply #8 on: May 18, 2017, 07:25:33 AM »
Right   :grin: :grin:
May be i 'll try your template also. it's a great job !!!!!
Offline Jáchym
    • Meteotemplate
« Reply #9 on: May 18, 2017, 07:33:39 AM »
All the available templates support some sort of forecasting API and I think all support WU as well - Saratoga, Leuven, Meteotemplate and Homeweatherstation
    • meteokerbach
« Reply #10 on: May 18, 2017, 07:52:57 AM »
i'll choose between weatherdashboard and your's.
